dual plane vs single plane wheel - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-29-2013, 10:46 PM Thread Starter
So I've searched but I can't seem to find a clear answer for my question. So far I've read that a single plane flows more 'down low' and dual is more efficient "up high". So using a billet replacement for the stock turbo, where is "down low" and where is "up high" in the rpm? Are there flow charts around?
harrisford is offline
post #2 of 9 Old 06-29-2013, 11:33 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
2003 Dual Plane MTW Billet Wheel Review.
This might give you some answers...
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 9 Old 06-30-2013, 02:35 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 141 Post(s)
Feedback Score: 3 reviews
While a different turbo my single planed Pmax pulls hard across the whole RPM band. I would expect the same for a stock turbo. Without any testing data to show the real values it's hard to say what you will really experience.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #4 of 9 Old 06-30-2013, 04:30 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I have yet to see where a dual plane wheel will flow more than a single plane on a 6.0. Or where a single plane wheel runs out of air in comparison to a dual plane wheel on a 6.0. I can see this possibly becoming an issue if the motor was spun to say 5000+ rpms, but with our 0-4000 rpm motors, the single plane wheel will flow more air every time in comparison to the 6x6, 12 blade dual plane wheels, and about the same amount of air as a 7x7, 14 blade dual plane wheel.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 9 Old 06-30-2013, 06:16 AM
madpowerstroke's Avatar
Unfortunately there really is no clean cut answer to which is better, the drive pressures are also different so that needs to be considered also. The single plane wheel requires more drive pressure a then the dual plane wheel at certain RPMs. At higher rpms the turbine needs to be driven harder on a single plane vs the dual since the blades are taking bigger bites of air. It all comes down to which one is best for the combination and use you want out of your truck. Since there is limited amount of flow numbers out there between the two and the ones there are, between the single 11 blade and 6x6 dual. I haven't found any flow numbers on the 7x7 wheels, but I would have to guess it flow very close if not better to the 11 blade. I'm still in process of making a flow bench to test out wheels, and turbos, but flow numbers are just a measuring tool, real world use depending on combination is different.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #6 of 9 Old 06-30-2013, 02:28 PM
Here's a clear answer, I replaced a cast dual plane with a billet MTW dual plane, boost comes on faster, initial throttle response is better (even with an IDP FICM tune), WFO EGTs are lower, and while I am not 100% sure, it looks like my mpg actually went up with this mod.
I always told my friends that I didn't want a big, high boost turbo, I just wanted it to come in sooner. Ask and ye shall receive.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #7 of 9 Old 06-30-2013, 03:59 PM Thread Starter
Thats exactly what I'm looking for. Now here's another question for you guys; is a stock turbo with a billet wheel capable of 500hp? A buddy recently dyno'd at 447hp with only a tune so I can't see it being unobtainable with some supporting mods but I'd like some educated views on this
post #8 of 9 Old 06-30-2013, 04:03 PM
N.S.D.Q.
Quoted: 141 Post(s)
It's a long shot...MAYBE..but don't think it could happen unless you spend some serious time tweaking tuning on a dyno. Some past reports gave tuning alone credit upwards of 470HP. Don't make any bets.
post #9 of 9 Old 06-30-2013, 04:23 PM
Motor Head.
robertc68's Avatar
Quoted: 40 Post(s)
I am going to replace my batmowheel,with a dual plane MTW wheel this week.i will report my results.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
