solid up pipe problems - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-27-2013, 10:02 PM Thread Starter
Has anyone had problems with their solid Y pipes? Cracking or problems with expansion and contraction? I can't see expansion being a big problem but I'm just wondering for a home project
harrisford is offline
post #2 of 11 Old 06-27-2013, 11:09 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I believe the problem is expansion between the motor and turbo and that's why the bellow pipes are there... Why do you want to eliminate them? If you completely eliminate them I would weld slip joints like sinister does so you can still have expansion and contraction. I opted for the bellows when I replaced mine... I'm sure someone will chime in shortly with their views on solid up pipes.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 11 Old 06-28-2013, 12:10 AM Thread Starter
So sinisters up pipes only truly seal when they're hot? I cant picture how else they would... as for vibration, both the manifolds and the turbo are solid mounted so I can't see vibration being a major issue between them. When I replaced my y pipe, the short side was cracked and torn open, right at the edge of the flex joint. In my mind, a simple solution to an apparent common problem would be to cut the flex joint out and weld in a short piece of pipe. Couldn't cost too much, might even be another cheap DIY fix that some owners could do
post #4 of 11 Old 06-28-2013, 12:26 AM
Quoted: 8 Post(s)
The exhaust gets so hot it needs to expand and contract or you will crack the y pipe eventually. Sinister y pipes are designed to slide in and out to compensate for this. Here is a link with pics of it
Sinister Diesel 6.0L Powerstroke Y-Pipes
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 11 Old 06-28-2013, 12:30 AM
Quoted: 8 Post(s)
I edited my first post... Vibration I was thinking of expansion like I stated later on in the post. My bad
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #6 of 11 Old 06-28-2013, 05:30 AM
PGreenSVT's Avatar
Feedback Score: 3 reviews
If you can do that then why not get stainless flex sections and weld them in and do the job right?
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #7 of 11 Old 06-28-2013, 07:39 AM
Turbos = Witchcraft
TooMuch03's Avatar
I agree 100%. Stainless interlock flex sections from vibrant are scheap, like under $30 and good for 90 psi of back pressure.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #8 of 11 Old 06-28-2013, 07:49 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Well they are like $50 for two from Summit Racing.
I agree though. That's all I use now.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #9 of 11 Old 06-28-2013, 07:52 AM
Turbos = Witchcraft
TooMuch03's Avatar
So under $30 a piece
2003 F250 6.0
Compounds FTW!!!
post #10 of 11 Old 06-28-2013, 10:11 AM Thread Starter
