SCT Tuner Issues?? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-27-2013, 12:57 PM Thread Starter
2006R.Raymo's Avatar
SCT Tuner Issues??
I just recently bought the sct livewirets and havent been having ang good luck with it. I drive an 06 powerstoke with only 97k on it. It was all stock when i got it and ran great. I installed MBRP's 4'' turbo back exhaust and an AFE intake. The only other thing i did was the blue spring upgrade. With the tuner on street under accel it feels like the truck wants to fall on its face and hesitates a lot. Feels like the power is there but then cuts in and out bad. I told Sinister diesel about it and had them make me a custom tune for the truck. The limited the power less then scts street tune but under 3/4 throttle you can still feel it like missing. And it doesnt feel like it makes any difference under WOT. Has anybody else had an issue like this before? Sinister told me i probably have low fuel pressure at the heads. I kinda find that hard to believe the truck was maintianed very well and i never had an issue before the programer.
2006R.Raymo is offline
post #2 of 14 Old 06-27-2013, 01:05 PM
licenced2burn's Avatar
Set it back to stock and see if it stops.
Tony
2005 F250 crew cab lariat,
4" lift 325/65/18 tires, head studs, built trans, egr delete, powermax turbo, 58v ficm from swamps with mild flash, 4" straight pipe, sct with innovative xtreme street and race tune's, blue spring upgrade
Stage 3, 190/100 injectors, and full fuel system on the way.
licenced2burn is offline
post #3 of 14 Old 06-27-2013, 01:06 PM Thread Starter
I have and it does stop.
post #4 of 14 Old 06-27-2013, 02:32 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Check your fuel psi, just because you maintained it, don't mean that the original spring is weak or you have a issue with the fuel delivery.
Tunes will bring out the weak points in your motor or trans.
What brand fuel and oil filters are you running? Aftermarket filters can cause running issues.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #5 of 14 Old 06-27-2013, 02:41 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
I agree 100% with Rich here and you should install gauges so you can monitor vital things!
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #6 of 14 Old 06-27-2013, 02:42 PM
Powerstroke Techie
Lilpooh's Avatar
Why you stalking me!! Don't you have a bracket to paint match the 6.4 intake?!?! HA!
Lilpooh is offline
post #7 of 14 Old 06-27-2013, 03:26 PM
I had a similar issue with IDP's SCT 3015. I called them and they said to try the others, I had the issues with the Street tune. I set it on Performance and it's been flawless...
2004 F350 CCSB Lariat FX4
Powermax
Edge CTS w/ EGT, Fuel Pressure
SCT tuner with Innovative Tunes
Fleetrite ELC, Rotella T-6
MBRP 4" turbo-back straight pipe
XDP Coolant Filter
NUC Motorsports Oil Bypass
Pioneer AVH3500BHS head unit, backup cam, Sirius/XM, Kicker speakers, Kicker 500.1 Amp, 2x Kicker 10" subs
89Foxbody is offline
post #8 of 14 Old 06-29-2013, 05:40 PM
Tired Marine.
Treynolds08's Avatar
I agree but the SCT Livewire TS is a monitor the TS means touch screen not to insult your intelligents I am just going with you don't know that model. But I do recommend a EGT probe and fuel pressure gauge I know IDP makes a kit for the EGTs to connect to the Livewire TS but not sure one the fuel pressure one.
Treynolds08 is offline
post #9 of 14 Old 06-29-2013, 05:49 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
:t ard::loo k:ive got my eye on you
A/C ASW A/W WINGS
post #10 of 14 Old 06-29-2013, 05:54 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Insulting my intelligence im not worried about that!! I know what ts stands for. hows it working for you? ohh its not. Get gauges that's why!!
A/C ASW A/W WINGS
