New or Used FICM Strategy VXCF9DA - Ford Powerstroke Diesel Forum
post #1 of 16 Old 06-26-2013, 02:57 PM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Viv is suggesting VXCF9DA as the latest known best strategy for my Truck but says i'd need a new computer, is it only the FICM or ???
TIA,
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 16 Old 06-27-2013, 03:22 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 115 Post(s)
Feedback Score: 3 reviews
If you are experiencing running issues it could be related to the PCM not the stragety. IF you are running the strat listed in your sig she might be saying you are not far from the "best" strat therefore you need a new PCM.
BTW PCM and FICM strategy codes are coded different from one another.
Without more info about the whole situation you are only going to confuse us more.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 16 Old 06-27-2013, 04:08 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
You might want to get a second opinion. Vivian recommends off the wall stuff sometimes. This make absolutely no sense.
RIP Mitch
the Org crew
PGreenSVT is offline
post #4 of 16 Old 06-27-2013, 04:12 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I'd talk to Matt or Eric.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 16 Old 06-27-2013, 04:45 AM Thread Starter
Quoted: 2 Post(s)
Ok, i'm trying to figure out the best tune and strategy for my truck. Working with Vivian on some tweaks to my tune she noticed my strategy was really old and possibly the source of most of my problems.
In her recommendation to "fix" the issue she said my Mechanic would need to reflash the truck but to do it would require a new computer and wipe out my FICM tune from Eric so that may not be feasible.
for the interim she's building a new tune to see if it fixes some of the issues with the Injectors and smoke.
Make sense now?
So the PCM is physically different from the ECM and FICM are there 3 computers all with separate tunes or ???
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #6 of 16 Old 06-27-2013, 05:09 AM
BACKYARDIGAN
Quoted: 4 Post(s)
No Denny. There are only two "computers" in our trucks. One is the PCM (also referred to as ECM) and the other is the FICM.
The "type" of PCM/ECM that is used on your truck is dependent upon the hardware configuration of your truck. (I.e. the 03s use a different PCM than an 06 does as its ICP sensor is on the HPOP where the 06 has its ICP sensor on the passenger side head)
The tune/strategy that can be ran on each truck is limited by the actual PCM that is determined by the year of your truck with its said hardware configuration. This means that an 03 truck can't use a PCM from an 06 nor can it run a strategy that is used on an 06 PCM and vice versa.
My recommendation would be to, instead of following Vivian's recommendation of spending a bunch of money for a useless strategy, I would switch to a tuner who knows what the hell he is doing and have your truck live tuned. Live tuning won't be limited by whatever strategy your running if the tuner knows what he/she is doing. Just my opinion.
Nate
post #7 of 16 Old 06-27-2013, 05:17 AM Thread Starter
Quoted: 2 Post(s)
Awesome, make perfect sense.
I'll just wait out the new Hybrid replacement Adrian is cooking up and try to find a
Live Tuner around DFW.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #8 of 16 Old 06-27-2013, 05:24 AM
BACKYARDIGAN
Quoted: 4 Post(s)
If you're in the state of Texas (I know I know. It's a HUGE state), I would go to Chris at TSD in San Antonio. Of course, Matt at Gearhead is in Bryan, TX too.
Nate
post #9 of 16 Old 06-27-2013, 05:26 AM
william_ace's Avatar
Quoted: 2 Post(s)
Come down to Truck Source Diesel and have Chris B. live tune your truck. It will be well worth it.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #10 of 16 Old 06-27-2013, 05:33 AM
BACKYARDIGAN
Quoted: 4 Post(s)
I live in West Virginia and I'm contemplating making the trip to Chris at TSD when I get my setup finalized.
I have his SPD tune that I run in my truck right now and it is hands down the smoothest running tune that I have ever ran. The power is SO SMOOTH, the transmission shifts AWESOME, and his tune is the coolest and cleanest running tune that I have.
The next tuner that I like the best after him is Eric, followed by Matt, and then that's it. Won't run anyone elses' tunes and I have too. That's how I know.
Nate
