12V Air Compressor - Ford Powerstroke Diesel Forum
post #1 of 32 Old 06-26-2013, 10:34 AM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
12V Air Compressor
A flat this Am got me to looking for an on board or portable air compressor.
What has the Knowledge Base used and recommend?
I have an inverter but don't carry a full size 110vac compressor.
Is a small 110 better than any 12v ?
37" tires BTW....
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 32 Old 06-26-2013, 10:49 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Don't get a 110v compressor unless you have a generator to run it, the small 110v compressors are useless!
There are many different brands of high quality 12v compressors out there that will do a great job, it just depends on how much you want to spend (more cfm = more $).
12-volt Air Compressor Guide - Technical Articles - Four Wheeler Magazine
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 32 Old 06-26-2013, 10:50 AM
portcity_gt's Avatar
Quoted: 1282 Post(s)
Viair has always been my choice.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #4 of 32 Old 06-26-2013, 12:27 PM
I've got a "12-volt air" in my bed.
It comes in a metal enclosure that doesn't take up much space but can also be removed and mounted in a toolbox or whatever. My dad has one in the front box of his pronghorn flatbed and its a short bed.
Got mine hooked up to the factory upfitters. It doesn't take long to air up a tire and its handy as hell. I'll get some pics this afternoon.
EDIT- there have also been a ton of farmers around here hook them to 24v and have em last just as long, then they'll really build some air.
http://www.12-voltair.com/pdf/sales_brochure.pdf from their website. Mine sits about 2-2.5 inches below bed rails.
2005 Lariat 6.0
4" TB exhaust to 6" tip
Tuned by the Wildman
Warren 190's
AD2 sumped
Studs and gaskets
EGR delete
CCV/Zoodad
Blackcloud413 is offline
post #5 of 32 Old 06-26-2013, 12:40 PM
jaysshortbus's Avatar
Try this !!
Viair, 100C 130psi Air Compressor Pump
Jay
jaysshortbus is offline
post #6 of 32 Old 06-26-2013, 02:07 PM
Snake's Avatar
Quoted: 46 Post(s)
Are you looking for a stand alone system? Or a compressor and tank mounted to your truck?
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #7 of 32 Old 06-26-2013, 05:09 PM
sfu7274456's Avatar
I would look at duty cycle also, you want something with a 100% duty cycle if you can swing it. I got one that is rated at 100% duty cycle and literally have ran it for hours on end with out issue. Now if I could remember who made it.
sfu7274456 is offline
post #8 of 32 Old 06-26-2013, 06:00 PM
F350R's Avatar
Quoted: 10 Post(s)
I have a 100% duty cycle 12v Viair that has trouble free. During the summer it gets a lot of use.
2004 F-350 CC LB Lariat FX4, SCT Erics Street tune, BPD EGR Cooler, BPD oil cooler, Empty CAT, Snows Water / Meth, Coolant & Oil bypass filters, 265x70x19.5 on American Force wheels, On board air system, Firestone air bags in cab regulator, dual air horns
F350R is offline
post #9 of 32 Old 06-27-2013, 05:21 PM
I bought a $99 12v at harbor frieght, it wont put more than 25 psi in my 35's!! When it comes to air compressors, u get what u pay for!
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
post #10 of 32 Old 06-28-2013, 12:18 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Vair is a good brand and not much more money either...VIAIR Part v/a10000 - Ultra-Light Duty Onboard Air System
Duty cycle is low, but for $150 it would be a great(and cheap) DIY starter kit! Fills a 1 gallon tank from 0psi to 100psi in under 2 min. Not bad for the price.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
