heads - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-25-2013, 08:51 PM Thread Starter
mustangmike6996's Avatar
heads
I know this has been discussed in a few head replacement threads but not in too much depth
I understand the heads get cracked and some have seats replaced etc
What is everyone doing for any performance or preventative measures with the heads when replacing or machining?
What kind of cost is involved?
mustangmike6996 is offline
post #2 of 10 Old 06-25-2013, 10:59 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
When I had my heads checked, I ended up need new valve seats. I paid $800 and the machine shop machined the heads flat,(both were off less than .004) magnafluxed, installed 16 hardened exhaust seats installed, 16 intake valve guides, 32 new valves were installed and lapped to the heads. They told me I didn't have to get new intake valves but I figured it was only $80 more they were already doing cylinder head work... so I figured why not.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 10 Old 06-26-2013, 10:59 AM
peixinho's Avatar
Quoted: 173 Post(s)
Wow... I was quoted $1600 dollars for the same work. I would have done it for $800
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #4 of 10 Old 06-26-2013, 11:04 AM
Quoted: 8 Post(s)
The guy that did my machine work is a friend of a friend, but I don't think he gave me a deal... But who knows. Maybe he did!
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 10 Old 06-26-2013, 11:40 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I would say if you can get the heads cleaned, magnafluxed, machined flat, new valves, guides, and 32 hardened seats installed for $1600, I wouldn't say that is too far off. That is what mine cost (of course I also had larger 6.4 exhaust valves installed too as opposed to 6.0 valves (1.5mm difference)). Then for another $500 I installed RCD's upgraded valve springs.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #6 of 10 Old 06-26-2013, 08:16 PM
Aretoo's Avatar
I just got mine done also. Took off 6 thousandths and fluxed them and pressure test. Also did seats and new guides. They also lapped the valves for proper clearances. Cost me $975.
Hello, my name is Nathan...and I am addicted to my skinny pedal!
2006 F250 Crew Cab Short Bed
Harley Davidson Edition # 01592
MODS
ARP Studs
Edge Insight CTS with EGT
IPR Gen2 EGR Delete
Sinister Coolant Filter
MBRP 4" turbo back
PHP Atlas 40 FICM Tune
Gearhead tunes
Rotella Ultra ELC
Aretoo is offline
post #7 of 10 Old 06-26-2013, 09:09 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
MustangMike, read the machining the 6.0 thread at the top of the General 6.0 forum. It will answer any questions you have about proper prep of the 6.0 heads. Well worth the read.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #8 of 10 Old 06-26-2013, 11:44 PM Thread Starter
I have read what seems to be every worth while thread on 6.0 heads. But just like this, I've seen prices range from 800-2000 for all the seats, milling, magnafluxing and valve inspection. If I am gonna pull the heads i think I'd rather have all of the seats done. Has anyone had problems with the area around the seats after machining and installing hardened seats?
post #9 of 10 Old 06-27-2013, 12:21 AM
Quoted: 8 Post(s)
No problems here... Cheap insurance to have hardened seats installed(especially on the exhaust side)
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #10 of 10 Old 06-27-2013, 05:16 AM
BACKYARDIGAN
Quoted: 4 Post(s)
No problems here either. Adrian also has (roughly) the same heads as I do and his have had WAY more abuse on them too and they are still holding up good.
Nate
