Who is running a FICM Tune and Larger Sticks - Ford Powerstroke Diesel Forum
post #1 of 22 Old 06-25-2013, 04:49 PM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Anyone?
After speaking with Viv she mentioned 2 other customers took off their ID FICM tune in favor of a smoother smoke free running truck.
Thoughts?
Also is this an old Strategy and what is preferred for an 05 ?
VXCF9N TQCI1NB
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 22 Old 06-25-2013, 04:59 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I had the Atlas 80 and loved it. But the egt's were too much for towin. I stepped down to the atlas 40 and wow what a difference. No egt issues but not as much fun either...
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 22 Old 06-25-2013, 05:24 PM
strokin6L's Avatar
Quoted: 4 Post(s)
Running 190/75's and ID's mild FICM tuning. I have less smoke with FICM tuning than running without it. I wouldn't run a 6L without it. As far as strategy goes...look on PHP website...it'll show you the strategy's.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #4 of 22 Old 06-25-2013, 05:27 PM
Fosterslaw77's Avatar
Atlas 40 just a slight puff of smoke taking of from stop, no cat 4inch turbo back
Fosterslaw77 is offline
post #5 of 22 Old 06-25-2013, 06:02 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I'm running an IDP Mild FICM tune and I've tried everything from stock, PHP Economy, Atlas 40, Atlas 80, and Hercules 100 and this is the best FICM tune that I have seen for my 190/100s.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #6 of 22 Old 06-25-2013, 06:54 PM
strokin6L's Avatar
Quoted: 4 Post(s)
I have only ran ID's FICM tunes...moderate and mild. So not sure how the others are. But my mild FICM tuning has less smoke than the moderate. Probably do to the increased pulse width. Love it tho.
post #7 of 22 Old 06-25-2013, 07:05 PM
pizza pig's Avatar
Ive tried all the ficm tunes with larger nozzles, erics was built for larger nozzles. Made the truck so much nicer to drive, and less smoke. Waiting for more parts before going with all custom ficm tuning.
pizza pig is offline
post #8 of 22 Old 06-25-2013, 07:13 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
I have ran the Atlas 40 on mine and IDP's mild FICM tune and it runs WAY better than with custom tunes alone.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #9 of 22 Old 06-25-2013, 08:11 PM
USAFBowman's Avatar
I've got 155/stock injectors and I run tunes from Wildman and an Atlas 80 FICM tune. Yeah I have some smoke on take off sometimes, but its really not that bad all that time. The smoke is only when i romp on it.
USAFBowman is offline
post #10 of 22 Old 06-25-2013, 08:27 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1682 Post(s)
Mods in sig but I too am running a ficm tune with bigger sticks. Mine is smokey with a full fuel tune. I need more air badly. I will say with my srl+ and the herc100 I have the least amount of smoke compared to all my other combos. The herc100 seems to clean mine up alot but the egts climb quickly, and I have notice my boost will hit 45-48 when the herc is on it.
toren302 is offline
