6.4 banjos - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-25-2013, 11:23 AM Thread Starter
6.4 banjos
these things. hearin all about em, any good news? why is the check valve there in the first place? no technical flaws to takin them out?
White 2004 F250 ext cab 4x4
240,000 miles
egr delete, blue spring, 5" mbrp exhaust, s&b intake and elbow, edge insight cts, sct w/ vivians tunes
4" rough country lift, 35x12.5x16 on mickey thompson black steels
11B
lot less
and a little more
holmes7410 is offline
post #2 of 9 Old 06-25-2013, 11:25 AM
colonel angus's Avatar
Quoted: 2 Post(s)
CCV mod is money better spent, or a Coolant Filter.
My .02
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #3 of 9 Old 06-25-2013, 12:09 PM Thread Starter
i plan to make a ccv mod when i get back home, deployed. and i have a coolant filter sittin at home waitin for me with the pyramid of other parts for me to put on
240,000 miles
11B
lot less
and a little more
post #4 of 9 Old 06-25-2013, 01:43 PM
jetjock15's Avatar
Quoted: 113 Post(s)
Ford seemed to think the check valves were required, just saying. My 155s with Ficm and ECM tunes never get the pressure below 60psi with my blue spring, don't really see the issue until you jump into some serous fueling, the the 6.0 or 6.4 banjos probably need replaced with better plumbing.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #5 of 9 Old 06-25-2013, 08:00 PM
mustangmike6996's Avatar
I have them along with a Blue spring kit. None of its installed... Im a little hesitant on the bolts tho.
mustangmike6996 is offline
post #6 of 9 Old 06-25-2013, 10:31 PM Thread Starter
i have the spring, i hear alot of good things about the spring. they call it an "upgrade" but it seems more to me like an update. just ordered the bolts. still kinda unsure about em though. want good reasoning/ explenation behind it. not "i got em cause they don't have a check valve". i'm not a rocket scienctist and dont want that answer. just a real answer
240,000 miles
11B
lot less
and a little more
post #7 of 9 Old 06-26-2013, 03:31 AM
All they'll do is flow a tad more due to being an open banjo. I have them and didn't notice a difference in anything. You may argue "what if the check valve stuck" that would suck. Never heard of it though.
The blue spring is a good thing. I don't hunk we should pay or updated parts, that's a cop out on fixing an F up.
07 ccsb 4x4, , swamps 58v(mild flash), rr, a1000, 225/50's, ported and polished heads, outlaw diesel headers, ported intake, dashboss fuel/egt, studs, twizted billet tranny
dfish1247 is offline
post #8 of 9 Old 06-26-2013, 01:23 PM
Not any noticable difference on a "stock" truck especially. Maybe it's more noticable on a truck running larger injectors but why wouldn't you just do an entire RR at that point which I believe most kits come with the updated banjos anyways. Ill say tons of people run the 6.4 banjos without issue like I do. I only put them in because someone bought them for me and I did it when I did the blue spring and a few other little mods.
"the C4 6.0" 2004 F350 srw lariat CC
ARP's, Liberator fire ringed heads, EGR delete, Brute Force CAI, 6.4 banjos, blue spring, cfm+, Livewire TS custom tune, 5"turbo back with 4" down pipe. Cowel Hood. Lifted on 35's. Suncoast tranny. Newly added 05 grill and harley headlights.
Amfw119 is offline
post #9 of 9 Old 06-26-2013, 05:51 PM
5fifty's Avatar
I put them on when I did my hg and studs, they were cheap and I didnt hear of any negative comments. Nothing gained, liked the idea of them possibly flowing better, don't know if they do. my .02
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
