ECM Rollback - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-25-2013, 09:57 AM Thread Starter
ECM Rollback
Looking for some ideas about shifting. My truck has had a 3-5 flair and something that resembles a flair in the 2-3 shift. My truck does it tuned or stock, doesnt matter. Now here is the big kicker, I have a new transmission with a modified direct drive and it still does it. It has done the same thing new or old trans, and tuned or not tuned. Newest strategies are VXBC9E2/TQBF0H4 my last ones were VXBC9N8/TQBD1N6. My big question is if i rollback will it help my shifting problems(im on the verge of getting rid of the truck because of it). Thanks
Amstaff is offline
post #2 of 7 Old 06-25-2013, 10:45 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Have your tune writer write you a tune based on one of the earlier strategies. When you load the tune you also load that strategy. No need for an ECM rollback.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 7 Old 06-25-2013, 11:17 AM
strokin6L's Avatar
Quoted: 4 Post(s)
Exactly what match said. I had Eric do this for mine. He did a roll back through the tune. I did it for using the ebp sensor. The new strategies don't use it.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #4 of 7 Old 06-25-2013, 11:30 AM
Motor Head.
robertc68's Avatar
Quoted: 40 Post(s)
Question is it possible to still run a newer strategy , once a rollback has been done? I understand the older strats use the ex sensor and the newer strat does not.The reason I ask is because Bill did rollback on my truck , one of the tuners adjusted my tunes for the older strat , but the other said after looking at the differences no adjustment was needed , this was for a tow tune,not sure if that matters.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #5 of 7 Old 06-27-2013, 06:01 AM
Motor Head.
robertc68's Avatar
Quoted: 40 Post(s)
Anyone know about this?
post #6 of 7 Old 06-27-2013, 10:09 AM Thread Starter
Thanks guys, so what your saying is paying for rollbacl is a waste? And Ill talk to my tuner.
Amstaff is offline
post #7 of 7 Old 06-27-2013, 12:29 PM
pizza pig's Avatar
yes, you just need a tune written off the newer base strategy, it doesnt matter what is flashed into the pcm because it can be over written with any other strategy.
pizza pig is offline
