Custom hood questions... - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 43 Old 06-25-2013, 07:55 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
I tried lookin this up in the search and did not see too much. As you may or may not know Ive been working with what I believe to be abit too high EOT's. I noticed this to be a issue with speeds over 75mph with oat's over 95*. I am currently lookin at a more free flowin grill set up but then I got to wondering what about a hood scoop (their is probably a better name for this but forgive me Im a 70's kid okay..)
If you look at the OEM hood set up the heat has no were to go but down. So if you had a reverse cowl induction style that let the air flow out would that be effective??
Just wondering what your thoughts are on these. Thanks
For example-http://www.streetbeatcustoms.com/Extreme-Dimensions/Hoods/Ford-F250-Superduty-Extreme-Dimensions-Duraflex-Cowl-Hood-_-1PC-_-107946/866872/
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 43 Old 06-25-2013, 08:13 AM
colonel angus's Avatar
Quoted: 2 Post(s)
I don't see where the air is going to get pushed up if it comes in at the same places.
Maybe i'm missing something and there is channels underneath?
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #3 of 43 Old 06-25-2013, 08:33 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Im wondering about the hoods with the opening facing the windshield. Wouldn't this give the air another route to exit, and there fore allow more airflow, and lower the under hood temps and allow more air through the radiators??
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 43 Old 06-25-2013, 08:39 AM
ZMANN's Avatar
Quoted: 1354 Post(s)
in theory it all about IAT the old air cleaner on top of a carb loved a cowl hood
but Ours are located up front
I have never seen anyone mention lower EGT's , ECT's or cooler AC due to the condenser flow improving with a cowl hood
I am also in the market just because thanks to Ford eliminating the hood blanket My paint is a little cloudy near the turbo
so If I am having anything painted it is going to be custom LOL
We Miss you Ronnie
ZMANN is offline
post #5 of 43 Old 06-25-2013, 09:05 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Boy o boy lookin at these things...they sure can get pricey.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 43 Old 06-25-2013, 12:08 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
Actually the area right in front of the windshield and where the cowl hood would end becomes a low pressure area. Look at how a Nascar engine sits in the race car. This is right where they draw the air for the carb from. Not much going out through here.
You need a heat extractor hood like Layson has on his truck.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #7 of 43 Old 06-25-2013, 12:19 PM
strokin6L's Avatar
Quoted: 3 Post(s)
The heat extraction hood might be the best bet
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #8 of 43 Old 06-25-2013, 12:20 PM
strokin6L's Avatar
Quoted: 3 Post(s)
Here's what it looks like
ford heat extractor hood - Google Search
post #9 of 43 Old 06-25-2013, 12:31 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1618 Post(s)
That's the hood I have and love it. Cant tell you if it makes a diff in temps but you sure can feel the heat come out of the upper vents.
Sent from AutoGuide.com App
toren302 is offline
post #10 of 43 Old 06-25-2013, 12:44 PM
portcity_gt's Avatar
Quoted: 1213 Post(s)
You would think a cowl hood lets air out the back....but that's not the case lol. The air flowing under the truck actually causes air to be sucked in at the cowl, hints the name Cowl induction.
As evident by the leaves always stuck to mine lol.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
