Radius Drop bracket? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 06-24-2013, 09:30 PM Thread Starter
06 Strokin's Avatar
Hey guys, I put a 2.5" leveling kit on my truck a while back and I think I messed with my caster quite a bit. I found some radius arm drop brackets on ebay that look like it might help correct that. Do yall think it would help to get them? Thanks in advance guys!
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
upgraded stc fitting
Cat ELC,
coolant filter
EGR delete
Reman tranny 126,xxx
06 Strokin is offline
post #2 of 21 Old 06-24-2013, 10:09 PM Thread Starter
06 Strokin's Avatar
I can't get anyone around here to install alignment cams is why Im asking. I also found some drop brackets that are from pmf if that makes any difference in quality from the ebay ones.
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
Cat ELC,
coolant filter
EGR delete
post #3 of 21 Old 06-24-2013, 10:19 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 15 Post(s)
You don't need radius drop mounts for such small of a lift. All you need is new cams to re set your caster. Radius drops are required when going above 2.5 like a 5+lift then you will also need a track bar bracket and swaybar end links and extended brake lines etc etc
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #4 of 21 Old 06-25-2013, 05:13 AM Thread Starter
06 Strokin's Avatar
Thats what I was thinking. I just can't find anyone around here to install them. I've asked 4 wheel parts down in Ft. Worth and they wanted a ridiculous amount of money to install BD's adjustable castor thing. I then tried the place that tey recommended and they couldn't do it. I call a few other shops and no one knows about it or can't do it. Do you or anyone else know of a shop in the Ft. Worth/Dallas area that will install them?
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
Cat ELC,
coolant filter
EGR delete
post #5 of 21 Old 06-25-2013, 06:58 AM
colonel angus's Avatar
Quoted: 2 Post(s)
Text Darryl tell him Denny sent ya... he's at North Central Ford off 75 / Campbell and can take care of anything mechanical you need done. Text him do not just drive up to Service.
214 870 3438
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #6 of 21 Old 06-25-2013, 10:08 AM
Quoted: 4 Post(s)
Feedback Score: 5 reviews
It takes 5 min a side to put cams in and no alignment needed with the correct cams
CT Performance, Inc. is offline
post #7 of 21 Old 06-25-2013, 11:07 AM
Just put them in yourself. Its not hard to do
06 f350: 8" ICON 2.5 resi's, ouo ala's, pmf track bar, dual stabilizers, custom 5" exhaust, 37" BFG km2's, 4.30s, 08 tailgate w/step, 08 tail lights, coolant filter, BPB oil cooler w/p 58v ficm and radiator, ARPs, 175cc, MTW s1 billet, ported intake, egr delete, onboard air and gearhead tunes
All the above just to haul the 900hp street mustang
94slowbra is offline
post #8 of 21 Old 06-25-2013, 03:30 PM Thread Starter
06 Strokin's Avatar
Anyone know if the icon alignment cams would work for me? And how do I go about installing them? Thanks for yalls help!
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
Cat ELC,
coolant filter
EGR delete
post #9 of 21 Old 06-25-2013, 04:20 PM
portcity_gt's Avatar
Quoted: 1530 Post(s)
ANY alinement shop here in Shreveport can install the caster camber cams.....I don't know why they're feeding you such bs.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is online now
post #10 of 21 Old 06-26-2013, 07:36 AM
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
If it's a 2.5" leveling kit, buy a 1.5* caster correction shim (we get ours from specialty products) and toss them in. It's as easy as remove the upper ball joint nut, remove the factory sleeve off the ball joint and replace with the caster correct shim ensuring orientation remains constant while torquing. For the specialty products shims, this means make sure the gap faces directly rear.
OCVeloMan is offline
