How to Change transmission parameters on X3???? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-29-2008, 05:32 AM Thread Starter
Spoolin05Stinker's Avatar
Location: not to far from the city of "Brotherly Loved"
okay I know im gonna get bassed for this but how do I change my transmisson parmeters on my SCT x3 , which is tuned from innovative? Its seems a lil rough from 1-2, 2-3, 3-4 ... I just wanna keep my tranny happy Do i have to unistall the tune from my truck and go to the updater or tune it with xtreme street already installed on my truck
2005 F-250
4"Mbrp With Cat
33x12.5x17 MT BAJA MTZ
Autometer Boost, Egt, Trans gauges
Green Drop in Air Filter
ARE DCU Series Cap Trucks gotta make me Money
MSD Daswhawk for the other parameters
Spoolin05Stinker is offline
post #2 of 2 Old 03-29-2008, 05:44 AM
Echo's Avatar
Firm quick shifts are actually better for the transmission than slow smooth shifts. When you plug the x3 into the truck and select custom tune, and you pick the tune you want, it should ask if you want to change parameters. Hit select to choose this option and then just scroll through the options until you find an option that says shift percentage (I believe that is what the option is called). It should be at 0% if you want firmers shifts you increase that number up to 25%. If you want softer shifts you make the number less. Or you could just call innovative and tell them you want the truck to shift smoother and they will take care of it.
Echo is offline
