Fuel pressure gauge - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-22-2013, 04:08 PM Thread Starter
hdodt's Avatar
Fuel pressure gauge
I'm looking at getting a fuel pressure gauge for my 06 6.0. Do I have to install an aftermarket sending unit or does the truck have one that I can get a reading from the ecm? If it takes a sending unit to be installed where does it tap into?
2006 F350 Lariat
EL CAT1 coolant and coolant filter.
95k miles. Oil cooler changed at 93k.
Oversized turbo oil drain tube.
hdodt is offline
post #2 of 7 Old 06-22-2013, 04:39 PM
KCCO!!
kells17's Avatar
The fuel pressure test port is located on the secondary housing right next to the oil filter. You can take it in and have it checked or put a gauge on it yourself. If you order a gauge, it should come with the sending unit which plugs into the fuel pressure test port.
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #3 of 7 Old 06-22-2013, 05:05 PM Thread Starter
hdodt's Avatar
Awesome thanks.
2006 F350 Lariat
hdodt is offline
post #4 of 7 Old 06-22-2013, 05:39 PM Thread Starter
hdodt's Avatar
So do you run a fuel line to the gauge in the truck or do you use an electrical sending unit and run wires? Where does everyone get this stuff from?
2006 F350 Lariat
hdodt is offline
post #5 of 7 Old 06-22-2013, 05:49 PM
KCCO!!
kells17's Avatar
ISSPRO and Autometer seem to be the most favored. Glowshift is another gauge manufacturer but some have had bad luck. Google/EBay them or check with some of the vendors here on the org. Each gauge should come with all necessary hardware, but double check before your purchase.
VA Strokers
757 Diesel
kells17 is offline
post #6 of 7 Old 06-22-2013, 06:36 PM
snafu!'s Avatar
You will need a m12x1.5 to 1/8npt adapter for the test port. Strictly Diesel sells a sender relocation kit that resolves clearance issues with the radiator hose.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #7 of 7 Old 06-22-2013, 06:39 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I would definitely not run fuel to the cab. Keep it as isolated to the fuel bowl as possible.
4R100, 2wd
330,000 + miles
jesilvas is offline
