Cat Questions - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-28-2008, 11:58 AM Thread Starter
Jetmek319's Avatar
Send a message via MSN to Jetmek319 Send a message via Yahoo to Jetmek319
Cat Questions
I am going to be installing an MBRP 4" Turbo back system in the next couple of weeks. Here in Colorado if the vehicle came with a cat, you must keep the cat installed. They do a visual check prior to any emissions testing. I would really like to "hollow out" the cat prior to installing the new exhaust system. On a previous F150 the cat was the standard ceramic/iridium cat and was therefore fairly fragile. I took a breaker bar, shattered the innards, and dumped it in a trash can. Is the cat on the 04' 6.0's the same type of material?
Thanks,
Jetmek319
Never, ever moon a werewolf!!!
2004 F250 SD 6.0 Crew SB,
Auto, CX Gray, AFE Stg II, 4" Turbo back MBRP exhaust, Stage I Fuel mod, Gunner Chrome, Recon Plastics, Marinco mod, Rhino Lined, DBA/Hawk Brakes, SCT Livewire w/ Elite Diesel Toons
, A.R.E Bedcap, Mag Hy-Tec Diff cover, Home Engineered Oil Bypass System, Kenwwod DNX5120, Clifford Auto-start, 58V Swamp's FICM.
= :burnout
Jetmek319 is offline
post #2 of 11 Old 03-28-2008, 12:02 PM
Let's Run'em
TwinTurboStroker's Avatar
Quoted: 10 Post(s)
Thanks,
Jetmek319
Yes ......happy hammering!
-Julian
4th 6.fo
TwinTurboStroker is offline
post #3 of 11 Old 03-28-2008, 12:11 PM
Streak's Avatar
Send a message via AIM to Streak
Why bother? 5 more HP?
And you're stupid if you destroy a working cat anyway considering you could sell it (and buy a shell)
Streak is offline
post #4 of 11 Old 03-28-2008, 12:21 PM Thread Starter
Jetmek319's Avatar
Thanks for the info TTS !!
= :burnout
post #5 of 11 Old 03-28-2008, 12:26 PM
Let's Run'em
Quoted: 10 Post(s)
With fuel prices you get what you can and the guy said he needs the shell, so why would he take the old cat off, buy a shell and then pay someone to weld it on for him.....the other way is easier
-Julian
4th 6.fo
post #6 of 11 Old 03-28-2008, 04:04 PM
Streak's Avatar
Because it's heinous to remove the cat for such a trivial reason.
Cats are worth a significant amount of money (a few hundred) which would take care of cutting the old one off and welding on a shell/dead cat that has been emptied.
Streak is offline
post #7 of 11 Old 03-28-2008, 05:04 PM Thread Starter
Jetmek319's Avatar
"Dead cats", of the emission type, are next to impossible to find in CO. Salvage yards will always answer with, "Sorry we can't sell those" to stay away from liability. Exhaust shops will run you out the door for fear of the Emission Big Brother. I would have to go out of state to try to find a shell that was worth anything and that would be more time consuming and expensive than shelling mine.
Butt, Streak, I will sell you mine for a bargain basement price of $300 if you'll shell yours and sell it back to me for $20. I was really looking for advice and information in order to make plan of action, and not opinions and offhand insults.
= :burnout
post #8 of 11 Old 03-28-2008, 07:01 PM
firestroke's Avatar
farmboys diesel has cat delete pipe in 4''. Take your cat to a muffler shop and have the put flanges on your 4" pipe and enlarge the cat pipe and add flanges. thewhen u want u can cange out the cat for the strait pipe.
Zach
04 F350 CC LB Fx4
Stock 6.0 with 6 speed Transmission
AEM Brute Force Cold Air
Edge Attitude with juice
Turbo back Exhaust With 5" Tip
Zoodad Mod
Nerf Bars
Tool Box
Front End Replacement
2008 Bed
firestroke is offline
post #9 of 11 Old 03-28-2008, 07:07 PM
loki's Avatar
take a blow torch if you have one and put the end of it in the cat and let it red hot then drop it in cold cold water that will make it alot easier to shell.
2003 ford 250 lariat 6.0
35x12.5x20
nitto mud grappler
mods:
afe stage 2
sct livewire
4" single with 6" tip
loki is offline
post #10 of 11 Old 03-29-2008, 05:59 PM Thread Starter
Jetmek319's Avatar
Thanks Chaps,
Both excellent ideas!
= :burnout
