Injector Spill Ports Explained - Ford Powerstroke Diesel Forum
post #1 of 32 Old 06-21-2013, 11:43 AM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Could someone explain what Spill Ports are or do and why some tuners prefer open to closed? is it Nozz size or what that dictates it?
I'm awaiting a set of 175's 30's from Jess who claims closed is better. my 175's 75's came closed and i have lope and tuning specific to them which will require a retune.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 32 Old 06-21-2013, 11:52 AM
turbotibbo's Avatar
subscribed
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #3 of 32 Old 06-21-2013, 12:06 PM
snopro_03's Avatar
My opinion, I think what it comes down to is that it's easier for the injector builder to create a larger flowing injector this way. Saves them time and money, you would assume this method would be less efficent since it takes special tuning to make the truck idle like normal again. Edit: The spill ports are designed to allow excess fuel to be spilled back into the feed rail. These typically don't need to be plugged with 190cc injectors and under depending on how the injector is reworked.
Chad
2003 6leaker
N.E.W 2.5 Truck
snopro_03 is offline
post #4 of 32 Old 06-21-2013, 01:31 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
Something to consider is whether or not an injector that has plugged spill ports actually flows what they're rated for.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #5 of 32 Old 06-21-2013, 05:32 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1680 Post(s)
I would also like to know how the plugs effect the longevity of the injector. When I first got my DDP sticks they idled smooth as glass and had good power. I had an AD2 with gauge from get go and always monitored FICM volts. I have only had them for 2 years and 25k and now cyl2 drops out at idle and sometimes I can feel a dead hole when loaded in OD. DDP plugs the ports to make a bigger injector the cheapest way possible. Just wondering if the plug stresses anything?
toren302 is offline
post #6 of 32 Old 06-21-2013, 05:57 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Plugging the spill ports is a cheaper/faster way of increasing the fuel capacity of a stock injector with minimal machining and shimming.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 32 Old 06-21-2013, 10:28 PM
SpeedyDBall's Avatar
So if I had my stock injectors made in to a set of 155 stock nozzle injectors do you think the spill ports are plugged?
'05 6.0 FX4 Lariat DRW:ARP, OEM HG's, Fully Updated, 03 turbo, Warren 155/stock, Pillar Guages(Boost, TFT, EGT, Oil Pressure), Fuel Pressure, Scan Guage 2, 6.4 banjos, Blue spring, MBRP straight pipe, SCT with Nate's tunes, Zoodad, DIY CCV Mod, coolant filter, T6, Final Charge ELC, Strategy VXCF4, Eco tuned FICM
Ficm Repair.com is the $%^&!!!!!!! Great service, and Ed is great to work with. Highly recommended!!!!!!
SpeedyDBall is offline
post #8 of 32 Old 06-21-2013, 11:38 PM
powerstrokecrzy's Avatar
Quoted: 250 Post(s)
Most likely yes if warren does them. My 175's have plugged ports. Had to have tune made for them to get rid of lope. It loped bad the longer you would let it idle, still does on my tow tune.
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #9 of 32 Old 06-22-2013, 04:29 AM
jetjock15's Avatar
Quoted: 113 Post(s)
My 155 warrens do, I assume. It idles same as stock, but when your coasting sometimes you hear it idle off and on real fast, causes no negative drive ability, used to it now and kind of like it. Sounds exactly like my old 7.3l when slowing down. I would guess warren D machines them to the right flow THEN plugs the port for more performance, so maybe they flow a bit more than advertised? Or not, whatever, they work great and warrens does them much cheaper than most so if that's how they do it, kuddos. My truck did not ever smoke on stock sticks and when I first dropped the 155s in I was "roalling coal" so bad traffic behind me dissapperared! Lol - so they flow way more fuel and that's a small upgrade (155s). I have since had tunes modified and run MTW S1 and now it clears it up for the most part but I can "roal coal" on demand as needed. Lol - I guess my point is my warren 155s work great and were a huge increase in fueling over stockers, I didn't think the jump would be so evident
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #10 of 32 Old 06-22-2013, 10:05 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
Unplugged injectors behave like normal until you increase the PW or increase the nozzle size. Plugged nozzles give you 155cc flow at max PW, but they also give you more flow earlier in the stroke with regular nozzles. This is why they smoke more on a stock tune. This is also why some need defuelling for idle or low PW flow. I doubt anyone was making 155s by cutting the internals, because you didn't need to! Just slip in a 3.5mm dowel and perhaps a light crimp and it is done. The downfall is why it was made to be ported, to relieve fluid stress from the hp fuel side to the relatively lower hpo side. Some have said the port also aids in fueling the chamber, and that may be somewhat true, but not really, since it doesn't open till very near the top of stroke.
Looking back at the history of the modifications, it started out as nozzles, but that really didn't do much. Plugging the port using various methods came next then, out came the cutting tools. Then the reliability started to suffer as the cuts got larger and more fuel was makings its way into the oil. Better reliability came from reman modifications and then came the open port and hybrids. Of course this was all mixed results since the turbo sizing was still being played with. Throw in the oil cooler posing as EGR cooler and headgasket issues, and not very many were happy with the new toy that wasn't reliable. As everyone now seems to be finding out, it is quite a good platform if you know the health of the engine.
There is no magic or mystery to injectors, it is just there wasn't much info available to the public at large until just a few months ago. It is kind of sad it took this long to get some of the info out. Almost 10 years!
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
