methonal mix - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-27-2008, 06:18 PM Thread Starter
twiztid1981's Avatar
Send a message via Yahoo to twiztid1981
methonal mix
ok tomorow im putin my devils own kit, what is the mixture, i got -0 an -32 which am i supposed to be usin, i looked around for the heet stuff but couldnt find it if some one could give me some help with the proper mixture that would be great
twiztid1981 is offline
post #2 of 9 Old 03-27-2008, 06:25 PM
justafarmtruck's Avatar
Send a message via MSN to justafarmtruck
what are u adding on???? water/meth.???
1996 F-250 "Dirty Secret" 3.0SB OD Duramax swapped 7.3
2005 2500 TwinTurbo Dmax
2015.5 Denali LML
9700IH TOTER HOME DT466E
Never forget- 97strkr will forever miss you Cameron.
justafarmtruck is offline
post #3 of 9 Old 03-27-2008, 06:41 PM
dustindiesel's Avatar
50-50 at he most..closer to 20-80 to be safe
2003 psd 6.0
red crewcab
16" suspension lift, 48" michelin xml's on 20x10 black rockstars, 6000k hid's, crossover steering, zoodad mod, ccv mod, modified up pipe to delete egr cooler,high idle mod, mbrp 3.5 downpipe, train horns(also on remote), diamond plate tool box, recon smoked cablights, Code670 alarm/remote start,100w reverse lights, oil-based underbody paint
**soon to purchase SCT rockwell 2.5 ton frt/rear
-8,520lbs with me in it
dustindiesel is offline
post #4 of 9 Old 03-27-2008, 06:43 PM
KVFD
redstroker_2002's Avatar
i like the 50/50 bud!
-Josh
2008 2500 LMM- Deleted, Blocked, Fueled, & Tuned by:
redstroker_2002 is offline
post #5 of 9 Old 03-27-2008, 06:46 PM
51% water 49% meth. thats what snow runs
2015.5 Denali LML
post #6 of 9 Old 03-27-2008, 06:53 PM Thread Starter
i need to know whats the curent mixture of the washer fluid i got, i got th 0 f an the -32 i dont know how its mixed whats the current ratio in the botlet, if i use the 0 f how pure is it basicly
post #7 of 9 Old 03-27-2008, 06:56 PM
Java's Avatar
Here it is..
+20 - 7% methanol
0 - 23% methanol
-10 - 28% methanol
-20 - 35% methanol
-25 - 38% methanol
-50 - 62% methanol
2011 6.7 F350 - Dads
2009 6.4 F350 - Brothers
2007 6.0 F350 - Mine
1997 7.3 F250 - Farm Truck
Java is offline
post #8 of 9 Old 03-27-2008, 06:56 PM
-20c is a 50/50 mix dont know what that is in "F" tho.
2015.5 Denali LML
post #9 of 9 Old 03-27-2008, 07:02 PM
FORDF35073PSD's Avatar
Send a message via AIM to FORDF35073PSD
just make sure you don't exceed 50% or your asking for problems, i did carelessly one time and within 300 feet bye bye head gaskets.
Late 1999 F350 7.3 powerstroke
DPS 6 Position Chip
Snow Performance Stage II water/Meth
Straight piped Bullydog 5"exhaust w/4" downpipe
Bullydog RFI intake
CAC Foil delete
CCV Mod
Gutted EBPV
Billet Torque Converter
Trans-Go shift kit
ARP Head Studs
Wicked Wheel
Mahle Pistons
346Hp and 656ft.lbs.
FORDF35073PSD is offline
