Gears or no? - Ford Powerstroke Diesel Forum
post #1 of 27 Old 06-20-2013, 11:32 PM Thread Starter
RoCkfiSh363's Avatar
Gears or no?
I have my axles apart for seals and fluid change. I was wondering if I should do away with the 3.73s and go to a 4.56 gear? I run 38 swampers and it can feel very sluggish and egts climb when on highway going up grades. Always have to put er in tow/haul even when empty to keep it away from 950 on the pyro. Would it be worth it? Or would I benefit more from a better turbo, mine never puts out more than 20 psi wide open with innovative insanity tune. Any input would be aaawesome. Thank ya.
05 EX Cab Short
8 inch Fabtech
38 inch SSRs on 17x10 Centerlines(powdercoated)
SCT Innovative tunes
Banks CAI
Offroad MBRP Stainless 4.5 " and up pipe.
Auto Meter EGT, Fuel pressure, Trans Temp, Oil temp, water temp gauges.
Blue spring , bored 3 hole banjos.
ARP Studs
OEM Ford gaskets.
EGR Delete, cooler delete.
Bulletproof stand pipes
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
Innovative 48v FICM Performance flash.
RoCkfiSh363 is offline
post #2 of 27 Old 06-21-2013, 01:03 AM
Gapowerstroke's Avatar
Gears! Your truck will feel like you put a better turbo on it and your tranny will thank you
06' F250 CC SR SB FX4 AT
Studs,S&B CAI, MRBP 4" exhaust 3.5" down pipe, SCT LIVEWIRE TS, Tuned by Eric (xtreme street and race), Innovative Inductive and Performance FICM Tunes, blue spring upgrade, 2.5" Carli Leveling kit, 18x9 BMF Novakane Death Metal with 35x12.50 Toyo MT's 3:73 gears.
Gapowerstroke is offline
post #3 of 27 Old 06-21-2013, 01:03 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Yes! definitely go for the gear change.
4.56 gears would be perfect for 38's, they will do away with the sluggishness and take the strain off you drivetrain which will make it easier on your tranny and also cut down your egt's.
I run 4.30's with my 35" tires and love it!
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #4 of 27 Old 06-21-2013, 01:17 AM Thread Starter
Sweet! Anyone have a preference on which brand to go with? I was looking at G2. I'm sure Yukon is the best by looking at the price tag.
05 EX Cab Short
8 inch Fabtech
Banks CAI
ARP Studs
OEM Ford gaskets.
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
post #5 of 27 Old 06-21-2013, 02:46 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Get gears for sure and then get new tunes from a different tuner - you should expect more than 20psi - no wonder you see high egts
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #6 of 27 Old 06-21-2013, 02:59 AM
Quoted: 863 Post(s)
Feedback Score: 3 reviews
OEM gears may be better. But if you go Yukon, make sure you follow the break in period. It does matter.
Corey@CNCFAB is offline
post #7 of 27 Old 06-21-2013, 07:43 AM
william_ace's Avatar
Quoted: 2 Post(s)
What RPM's do you run at 70? I'm thinking of re-gearing and am inbetween 4.10s and 4.30s.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #8 of 27 Old 06-21-2013, 08:05 AM
Mathematically speaking, 4.56s are where you want to be. When it's all done, your speedo should read pretty darn close also. The 38s "sped the truck up" and the 4.56s will "slow it down" so to speak.
The ONLY down side to 4.56s is that if you ever go back to 35s, you're going to be over geared. Not bad in town, but it would be rough on more than 15~20 miles on the highway.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #9 of 27 Old 06-21-2013, 08:42 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Don't cheap out on the gears and while you're at it maybe upgrade the diffs too.
RIP Mitch
the Org crew
PGreenSVT is offline
post #10 of 27 Old 06-21-2013, 08:49 AM
layson's Avatar
Quoted: 83 Post(s)
I run 4.30's with 38's and its ok, at 70 mph I am running right around 2k rpm, and mine is a 7.3. It is definitely great for towing. If you spend any time unloaded and on the freeway over 70 mph you will probably hate 4.56's. There is no way I would put 4.56's for 38's, I would run that with 40's maybe, but I actually liked the 4.30's with 40's combo when I was running that. Wasn't a tow pig setup like that.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
