500 rwhp - Ford Powerstroke Diesel Forum
post #1 of 43 Old 06-19-2013, 05:11 PM Thread Starter
500 rwhp
500 Rwhp seams to be the magic number. Over 500 built trans needed. 155 sticks seam to the pick. Any bigger can't tow and you need a RR fuel system. Atlas 40 seams to be the ficm pick for dd and towing. Now turbo choice is the question since there is no stage 2. Any suggestions?
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #2 of 43 Old 06-19-2013, 05:19 PM
What about stock sticks stock fuel and "mad" something turbo that made 500hp?
How bout that for towing? I did hear the ficm was tuned.
How bout cheapest/easiest most power least smokey/laggy set up for daily driver work truck jobbie!
01 F-350 reg cab srw 7.3
Important stuff:
Beans stage 1 injectors, Beans 6 position chip
Dieselsite ww2, boost fooler, wastegate controller
gauges, upgraded up pipes,
afe intake, 4" flow through muf w/turn out
BTS transmission, 6.0 cuuuler
35"toyo mt on 18" black kmc addicts
06 F-350 cc srw 6.0 lariat
build being planned...starting with the cab off
frashdog is offline
post #3 of 43 Old 06-19-2013, 05:25 PM
05_PSD_Erik's Avatar
Intake, tune and exhaust... that's all I needed
Sorry, just
As mentioned above, look into the MTW (mad turbo works) turbos they are getting GREAT reviews around here!
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #4 of 43 Old 06-19-2013, 05:38 PM
The Silent Service
colo_dually's Avatar
Quoted: 24 Post(s)
With the right tuning, and proper relearn - the transmission is probably closer to 530RWHP and reliable.
For the injector/turbo combo, I'd run an MTW with 155/30s. I'm intending to make the 500RWHP without the injectors - but there is a bit more that goes into that. (check thread in sig)
For FICM tunes, I'd run an economy (+25HP) or the Atlas40 file - depending on how heavy you are talking about towing.
You will need a solid towing file written, depending on which turbo / injector you run and your maximum load.
MTW may be able to continue to build stage 2s, another option may be that newer MTW Powermax combination.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #5 of 43 Old 06-19-2013, 06:17 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
A MTW Stage 1 or Pmax with 11 blade single plane billet wheel with a set of 155 injectors should land you over the 500hp mark, so long as your truck's HPO system is capable of 3800-4000 psi of ICP and the tuning is there.
Tuning will be the key to achieving this.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #6 of 43 Old 06-19-2013, 06:27 PM
Chatham036's Avatar
Quoted: 136 Post(s)
excuse me sir... I seem to recall you posting this a couple weeks back
I guess I'll just end with, I'm with you in that I will NEVER recommend 155cc injectors to anyone wanting over 500hp.
Just pickin on ya Nate
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #7 of 43 Old 06-19-2013, 06:30 PM
BACKYARDIGAN
Quoted: 4 Post(s)
Well you are correct...
Very well. I retort. 175/stocks. If Frank (twoicebergs) can tow with 190/50s and a durastroke, you can tow with 175/stocks and a Stage 1 or Pmax with billet wheel and it stands an even better chance of hitting over 500hp.
The stock tranny should hold up well at 525-530hp levels.
Nate
post #8 of 43 Old 06-19-2013, 06:31 PM
BACKYARDIGAN
Quoted: 4 Post(s)
175/100s with a Stage 2 have made over 550hp and towed 14k by one member down in GA.
Nate
post #9 of 43 Old 06-19-2013, 06:35 PM
Chatham036's Avatar
Quoted: 136 Post(s)
155/stock has been proven to achieve over 500rwhp in some trucks, however this does not always happen.
175/stock will be a good injector size to achieve the horsepower mark you are looking for. These injectors commonly fall in 540 - 575 rwhp range when matched with the proper charger.
post #10 of 43 Old 06-19-2013, 06:38 PM
Dirty_Stroke's Avatar
I'm running 155/stock nozzle injectors and my track times show that my truck is somewhere around the 530rwhp mark. I have killed the stock trans, but I do not "baby" the truck by any means. It tows very well. I'm not sure how heavy your talking about towing but I would consider 175 injectors. Mainly because we all know that you will always want just a little more power out of it and 175's can be defueled for towing heavy, but still allow a good bit of fuel for all out race tunes and max power. I suggest the PHP FICM tuner also. I love mine! And its nice to be able to drop back to the Atlas 40 when you hook the trailer up and load the Hercules back when you unhook. As for turbos.... I can say a few things and you take them as you wish. I have the MTW Hybrid with the original Batmowheel. My truck saw NO gain in track times, mpg, or lower EGT's over the stock charger. I know that MTW now has a new billet wheel that is suppose to change that, but I have yet to see a review. I have seen enough great reviews with the Stage 1's that I would suggest going that route, staying with the stock charger, or looking elsewhere for a turbo.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
