EGR Delete. - Ford Powerstroke Diesel Forum
Old 03-26-2008, 11:02 AM
EGR Delete.
What are the pro's and cons of doing a EGR delete. I mean removing all emissions stuff off of a 6.0?
do you get more performance???
Old 03-26-2008, 01:55 PM
there are zero cons. the pro is it prevents an egr cooler failure. No, you do not get more performance.
Old 03-26-2008, 07:27 PM
Thinking about a delete on mine. Read an article that it not only stops the flash boil that happens in the egr cooler, but adds lowend torque in normal driving due to spent fuel not being recycled (egr is closed at wot). Has anyone else heard or read this?
Old 03-26-2008, 07:58 PM
I've read that but you will not notice any added low end torgue. I just believe whatever marc tells me and he said there is zero performance increase.
Old 03-26-2008, 08:05 PM
Is it something you can do yourself or do you need to be a mechanic?
Old 03-26-2008, 08:16 PM
having some mechanic ability will definitely help....if you're removing all egr related parts.
Old 03-26-2008, 08:36 PM
Will the egr delete change the results of emissions test results? Will it pass/fail?
Old 03-27-2008, 03:06 AM
I would guess it would fail. I live in NC Diesels are exempt from emissions testing.
Old 03-27-2008, 03:16 AM
Their is a great write up in this months diesel power magazine for the EGR delete.
Old 03-27-2008, 04:45 AM
I also made a write up with pics, its in the 6.0 Tech folder.
Also look in the 6.0 problems forum for the "Takeing on the EGR cooler" post. There is alot of good info in there to.
