Bully Dog WatchDog... any good? - Ford Powerstroke Diesel Forum
post #1 of 37 Old 06-18-2013, 07:05 AM Thread Starter
jmoney330's Avatar
Hey all,
Well I'm in the process of attempting to put my gauges in. Not goin' so good but, whatever.
Anyway, while looking through XDP's website I saw Bully Dog Watchdog for a pretty decent price. I then went to Amazon and saw it for $212 shipped. That's a pretty good deal on a monitor, PLUS the driving coach!
Anyway I was originally looking at getting the SCT Livewire to use as my programmer and monitor, but I think I could go cheaper with the WatchDog and a SF3.
What do you guys think about it? Anyone have one? I really like how it can mount on my A-Pillar with my other gauges! That's practically the selling point for me.
jmoney330 is offline
post #2 of 37 Old 06-18-2013, 01:27 PM
sfu7274456's Avatar
Nope.
Elm327 + Torque Pro + any Smart phone or tablet = exact same thing total investment less than $25.00 not including the phone.
sfu7274456 is offline
post #3 of 37 Old 06-18-2013, 02:17 PM
05_PSD_Erik's Avatar
Seems like a decent monitor. I considered running this monitor myself. I had an older Bully dog monitor on my 6.0 and it worked good.
As far as the bluetooth dongle/APP deal, I, personally am not a fan of that setup, I know a lot of people run it and love it, but I use my Bluetooth connection for a headset while driving so, that's out for me.
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #4 of 37 Old 06-18-2013, 03:36 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1774 Post(s)
When I ran my bullydog I like the monitor. That said you need to read the fine print. Its 212 for the monitor and the another 150ish for the egt probe kit.
Sent from AutoGuide.com App
Originally Posted by Heavy_GD View Post
Merged, because lamp.
toren302 is online now
post #5 of 37 Old 06-18-2013, 03:47 PM
ZMANN's Avatar
Quoted: 1892 Post(s)
looks like the size is deceptive ?
also I might just save a few more bucks for a Insight CS or CST
and get mileage coach / performance test /maintenance manager
and an easy to read touch screen
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #6 of 37 Old 06-18-2013, 06:13 PM
Check out scangauge II.
2016 F250 Lariat
the06wildebeast is offline
post #7 of 37 Old 06-18-2013, 06:55 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Feedback Score: 3 reviews
You should also contact BD about what parameters it can monitor for the 6.0. IIRC, it doesn't do any of the 3 FICM PID's.
Just looking at the BD website at the Watchdog, it only does 21 PID's, that's half the amount of PID'S that you can watch with DashBoss, Scangauge, Torque, and Edge CS/CTS.
You get what you pay for!
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #8 of 37 Old 06-18-2013, 08:59 PM
turbotibbo's Avatar
I run a mini max for gauges because I didn't research before I bought my tuner, and sct for tunes via the sctx3 . I am sure the watch dog and mini max are the same platform / monitor . I don't mind it for the 6.0l , it shows most things but not ficm info and that bothers me . it shows icp in volts ? any one know what that means ? if I had to do it over I would have just bought the sct touch screen or something like dps new tuner hope this helps
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #9 of 37 Old 06-18-2013, 09:04 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
The ICP is a 0-5v pressure sensor. It reads the high pressure oil leaving the HPOP.
Lilpooh is offline
post #10 of 37 Old 06-18-2013, 09:28 PM
turbotibbo's Avatar
so would 4.1 v at an idle be normal
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
