Towing with Big Sticks - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-18-2013, 06:25 AM Thread Starter
twoicebergs's Avatar
Quoted: 47 Post(s)
Not much info out on the forums with any details. 190/50s and stage 1 turbo.
I towed my boat about 240 miles yesterday at 60 mph and part way into the pull I decided to change tunes to see if I could improve fuel economy. So about every 50-60 miles this is what I saw. I didn't have a tow tune available, but it was interesting to see what the results were with what I had available. The transmission shift points were fine, except the T/C locking in 6th was a bit too low on the Extreme for some of the hills. Smoke was pretty much non-existent.
The boat and trailer are about 6,000 lbs (23' wakeboat).
Aggressive Street (worst economy. However, this tune has the best economy running empty.)
Mild Street (about 2-3 mpg better than worst)
Stock (warmest temps. About same fuel consumption as Mild)
TDP Extreme (Great EGT and power. Economy slightly lower than Stock)
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #2 of 14 Old 06-18-2013, 07:22 AM
sealeveloc's Avatar
Quoted: 21 Post(s)
Garage
Good to know man! Are you running a MTW stage 1 and who did you get the 190's from. I tow a lot and want to add some larger injectors probably 190's. I was thinking 35-50% nozzles. I like to see what a tow tune does for ya.
Byron
O6 350 XL
The usual I wanna go fast mods,
maybe a lil more,
maybe a lil less
sealeveloc is offline
post #3 of 14 Old 06-18-2013, 07:23 AM
sealeveloc's Avatar
Quoted: 21 Post(s)
Garage
Oh! And have you done a fuel system? I can't see sigs on the phone app
Byron
O6 350 XL
maybe a lil more,
maybe a lil less
post #4 of 14 Old 06-18-2013, 09:24 AM Thread Starter
Quoted: 47 Post(s)
Are you running a MTW stage 1 and who did you get the 190's from. I tow a lot and want to add some larger injectors probably 190's. I was thinking 35-50% nozzles. Oh! And have you done a fuel system?
Stage 1 Turbo made by me (MBM). Probably identical to the early MTW S1.
190/50s open port, MBM. The result of my tread on making larger injectors.
As far as fuelling goes, just the blue spring for now (I was pretty stable at 60 psi prior to the new spring). Pressure hasn't dropped below 42 psi at max fuel and shorter WOT runs (who really knows what it is at #7 & #8). In any reasonable driving it never goes below 70 psi. I am still toying with the idea of a regulated return, but I don't need it for the <0.1% of the time it would be useful. Now if it becomes a track truck or a dyno queen, then it would be on the "to do" list.
Frank
Working for Toys
post #5 of 14 Old 06-19-2013, 07:57 AM
sealeveloc's Avatar
Quoted: 21 Post(s)
Garage
I read the first few days of it but haven't checked back on it in a while.
Do you plan to step up the weight that your towing? I haul around 10k, 2-4 days a week. And I think I'm gonna try 190/30's, but a little scared to with towing all the time. Might go with 175's. I have a back up 6.0L if there to much, I don't know which direction to go. Guess I'll just keep reading. Lol
Byron
O6 350 XL
maybe a lil more,
maybe a lil less
post #6 of 14 Old 06-19-2013, 09:24 AM Thread Starter
Quoted: 47 Post(s)
I don't plan on pulling anything heavier in a while. However, with tuning for the larger nozzles, there is no reason to be concerned. I just tried out and IDP tow tune for my injectors last night and it ran even cooler than what I posted above. Also, the examples above were tunes for stock sticks, so even with slight over-fuelling (read performance) and a stage 1 turbo it works just fine. The only time it could be a factor was if the PW of the tune was too large for the turbo or if you worked the truck too hard and over-heated the engine.
Frank
Working for Toys
post #7 of 14 Old 07-15-2013, 07:31 AM Thread Starter
Quoted: 47 Post(s)
Over the weekend I towed 4 horses and gear (about 10k) for about 3 hours. It was flat with very little wind and a mid 80s temp. I used IDP's tow tune. I'll let you guess which one was loaded. My true delta is 2* less, the EOT over-reads by 2*, not that it really matters much. Fuel economy loaded was 16 mpg, better than expected.
Frank
Working for Toys
post #8 of 14 Old 07-15-2013, 07:37 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Top one is loaded.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #9 of 14 Old 07-15-2013, 01:24 PM
The Silent Service
colo_dually's Avatar
Quoted: 30 Post(s)
Was that IDP Towing file adjusted for your 190s, if so do you know how much fueling was pulled?
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #10 of 14 Old 07-15-2013, 01:52 PM Thread Starter
Quoted: 47 Post(s)
Yes, he had the parameters. However, I don't know what the adjustment was from his other performance tunes. I do know that the PW is fairly typical of most stock stick tow tunes at highway speed under some load. The PW doesn't go up much higher under full acceleration, but the ICP goes to 4,100 psi. So that is where the adjustment must be.
Frank
Working for Toys
