05 Engine Rebuild - Ford Powerstroke Diesel Forum
post #1 of 17 Old 06-18-2013, 07:02 AM Thread Starter
05diesel60's Avatar
05 Engine Rebuild
Hey guys, just checking in from the desert for some input. I am thinking about doing a complete engine overhaul minus the new parts I have on. You can see what I have in my sig and here is some food for thought for some future stuff.
1) Should I replace the crankshaft when I do an overhaul or just take the stocker out and get it rebalanced?
2) Should I keep the pistons as stock or go .010 over? Any advantages or disadvantages to one vs the other?
3) EDE heads with a stage 1 cam, carillo rods, new ported intake manifold, new coated headers, have heads and block decked and milled. New up-pipe, BPD oil cooler upgrade kit, EDE billet flexplate, RCD fuel delivery and return.
This is what I'm looking at so far. Any input on all of this would be great.
What I'm looking for is 100% reliable performance and an upgrade that is going to make the engine like new again. I'm not looking for crazy, however one and done is my motto for big builds. Anything I should be concerned with on this list. Btw I'm getting the EDE parts from Rudy's Performance.
2005 Powerstoke CC SB Lariat
SCT X3 Tuned by Eric @ IDP
, Edge Insight, FICM Upgrade with Re-flash, Fabtech 6" Performance Lift with 35" M/T Baja ATZ's, Banks Turbo Back Dual 4" Exhaust, Kitty Delete, Banks Intake, Banks High Ram Intake, Banks Intercooler, Garrett Powermax, Casserly 155cc Injectors, AirDog II, Blue Spring Upgrade, 6.4 Banjo Bolts, EGR Delete Kit, Mag-Hytec Rear Diff. Cover with Eaton True Trac, CAT ELC, ARP Head Studs, Royal Purple Oil, Rev X Oil Additive
05diesel60 is offline
post #2 of 17 Old 06-18-2013, 07:33 AM
Therabbittree's Avatar
How many miles? I just rebuild my engine it had just under 210k when head gaskets went. My pistons were mint, my crank was mint my bearings were ok. I would not waste your $ on a new crank, or pistons. Clean yours up and do new bearings, rings etc.; I had my bloack hot tanked and honed there was no ridge and my original hone marks were still there in the cyls at 210k etc.
The only way i'd do the crank would be if it was a stroker with custom rods etc...
I'd put you $ into the BPD air cooled oil cooler setup, An Adreneline HPOP if you have the older style HPOP ie cast iron cover ves 2 piece with HPOP sticking thru it.
You parts list and mods looks good. head work is good ie, valves springs and 3/8" pushrods, new lifters, and cam etc....etc.. fuel system ie lift pump upgrades would be good idea too.. Just doing those parts is going to be over 10k in parts, after adding up the little stuff. I have close to 12 in my build and I'm not done, and i have stock cam, stock valves springs, stock pushrods, etc. My thread is the driveway build in the excursion thread.
Let us know,
Thanks,
Deo
Therabbittree is offline
post #3 of 17 Old 06-18-2013, 07:35 AM
Forgot to add THANK YOU For your Service!!!!
post #4 of 17 Old 06-18-2013, 07:56 AM Thread Starter
05diesel60's Avatar
Yeah I am not trying to break the bank in the process but I just want to do this one time and not worry about it again for a looooong while, God willing. Another route I am thinking is the Stage 2 crate engine from performance machine and having them take a few things off I won't need. I want to ask them about their heads and what they do to them as far as port and polish and what the materials are in their valve train upgrade. I'm using the EDE heads as a baseline and trying to get everything as streamlined and simplistic as possible, i.e. I don't want to buy 15 different parts from 13 different places. So if the stage 2 crate is good for what I want can I just do that and call it a day?
I really do want to go with new carillo rods simply put because once again I want a one and done build, and also when this is over with I will be doing a Snow performance stage 3 water/meth for schnits and giggles. After I posted this I started digging around and have come up with the Performance Machine stage 2 crate. Are there any issues going that route either?
Thank you
post #5 of 17 Old 06-18-2013, 08:31 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Unless you are looking for big hp I wouldn't bother with anything other than the stock crank, rod, and pistons. If you can get away with just honing the cylinders are new rings on the pistons That's what I would do. That'll easily live with 700 rwhp all day long. Save your money for other things.
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 17 Old 06-18-2013, 08:59 AM Thread Starter
05diesel60's Avatar
Thanks Green. I'm going to price out 3 different routes and figure out which one to go with as far as price is concerned.
post #7 of 17 Old 06-18-2013, 12:37 PM
kdogg85's Avatar
I have to agree, unless you are looking to blister 40" tires in 4wd. A basic stud and update job will do it. Buy the parts individually or check out Asheville engine. There is a guy on here(gearhead2012) I believe, that really got into detail on porting the heads. It's a lot of time but will save you money.
But if you insist on going that deep, add arp main studs as well.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #8 of 17 Old 06-18-2013, 01:09 PM
colonel angus's Avatar
Quoted: 2 Post(s)
Be sure to use the latest Black Onyx Gaskets!
{Bracing}
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #9 of 17 Old 06-18-2013, 08:38 PM
cbenn's Avatar
Quoted: 2 Post(s)
bullet proof 6.0
Need some advise as I have a 6.4, my brother has a 05/6.0 and wants to bullet proof it, does anyone know if Performance truck products (Nate) does rebuilds/bullet-proofing? I will call in the morning but just wanted to see ahead of time, so if this plan doesn't work out who around Dallas does good work, I live up here in Seattle so not familiar with what shops are in the area.
Your replies are greatly appreciated.
cbenn
Just purchased a new 2016 CC
SOLD
2008 F350 CC SRW, 4X4/LB
Spartan Tuned/Spartan TCM
1722 Elite Head Studs/ChromeMoly pushrods
Bullet Proof 1/2 oil cooler kit
4" Down Pipe/4" DPF/Cat Delete
Diamond Eye 5" DPF back/5" Areo Turbine Muffler
3" CAI/inter cooler
S&B-CAI
CCV mod w/catchcan
Big Wig Sway Bars
PMF Traction bars
Icon 2.5 front coil springs
Bilstein shocks/Top Gunz dual stabilizer w/Bilsteins
Airlift/remote airbags
Viper 5701 w/SmartStart
cbenn is offline
post #10 of 17 Old 06-18-2013, 11:10 PM
Quoted: 5 Post(s)
Run don't walk away from the pmm crate motor!!! May want to look into blackwater or Asheville but I wouldnt pee on pmm if they were on fire.
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
