Wanting to BEEF UP my 05!! - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-17-2013, 05:36 PM Thread Starter
Question Wanting to BEEF UP my 05!!
What would be the best package with or without doing the entire bulletproof?
I am wondering if I can beef it up a little bit without doing all of that or if it just needs to be done. Chip, Exhaust, Air intake.....Any help would be great!!!
05 F250
Stock
78,000 Miles
Daily Driver
Thank you!!!
Becknasty3806 is offline
post #2 of 14 Old 06-17-2013, 05:42 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Exhaust and intake are completely different from solving the EGR and oil cooler issues.
Coolant filter would be the least amount to do.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 14 Old 06-17-2013, 05:42 PM
RRFPD445's Avatar
Egr delete and a new oil cooler. Coolant filter. Sct programmer. 4" turbo back exhaust; no cat or muffler.
Sent from AutoGuide.com App
2005 F250 Crew Cab Lariat
6.0L Powerstroke Diesel
Arp studs
Mad Stage 1 Turbo
Stock sticks
4" turbo back straight pipe
RRFPD445 is offline
post #4 of 14 Old 06-17-2013, 05:45 PM Thread Starter
Now would that be ok without doing the head studs and what not?
post #5 of 14 Old 06-17-2013, 05:48 PM
JGman141's Avatar
Yes but it depends on how you drive it.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #6 of 14 Old 06-17-2013, 06:00 PM
colonel angus's Avatar
Quoted: 2 Post(s)
#1 EGR Delete
#2 Coolant Filter
#3 Scangauge II or SCT Tuner (Diagnostics & Tunes)
#4 Hybrid Turbo
#5 ARP Studs
#6 MBRP Exh.
Rationale.....
#1 is inevitable #2 Cause ya no it's crap in the coolant #3 You need to know the condition of your Truck #4 Why Not! #5 You No you need 'em #6 Because
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #7 of 14 Old 06-17-2013, 06:06 PM
this. wisdom here.
Sigster is offline
post #8 of 14 Old 06-17-2013, 06:09 PM
05_PSD_Erik's Avatar
Also, leave the stock air intake in there. It filters the best of anything out there and unless you plan on going over 500rwhp (turbo, injectors, so on and so on) the stock setup will flow just fine.
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #9 of 14 Old 06-17-2013, 06:14 PM
Quoted: 2 Post(s)
Originally Posted by Sigster View Post
this. wisdom here.
No reason to replace your Oil Cooler until you've plugged it up flushing the system.
And no reason to replace it until you're ready to change to ELC.
Capture as much crap as you can via a filter while you monitor the deltas.
You might need it now, or a year or so.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #10 of 14 Old 06-17-2013, 06:23 PM
D
This is HUGE!
Get a good monitoring solution (Edge CS/CTS is a popular one) and keep an eye on the coolant temp and oil temp, if they start getting big differences in the numbers (IIRC 6-8* at 65mph flat ground, empty truck) if that delta starts changing, get ready to flush the coolant system and replace the oil cooler. Do your flush before changing coolers!
Type RS BOV
CAI
Muffler Delete
