Some questions about 04 6.0 - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-17-2013, 03:51 PM Thread Starter
wellsdiesel78's Avatar
Hey guys just got a 04 bought it not running as it turns out someone put gas in it. I have drained the gas and flushed the gas out ficm is good I have good oil and fuel pressure buzz test is good in all 8 so I'm gonna say I need new injectors! Any suggestions would it be ok to get some bigger ones I don't no truck has 190k on it I found a good deal on a set that are 190 cc but I'm thinking that's a little much on a pretty much stock truck otherwise! Please help your input would be appreciated and if anyone has a set of injectors cheap I may be interested thanks again in advance for your time!!
Sent from AutoGuide.com App
wellsdiesel78 is offline
post #2 of 10 Old 06-17-2013, 07:20 PM
JustinOOO9's Avatar
Quoted: 584 Post(s)
Garage
will it not start? has a miss at idle, or certain throttle positions or? " not running" is a little vague if you need the right way to go.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s, JW Vbody.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #3 of 10 Old 06-17-2013, 11:01 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Yep, why do you think you need injectors? And 190's are too big for a stock motor IMO.
RIP Mitch
the Org crew
PGreenSVT is offline
post #4 of 10 Old 06-18-2013, 05:33 AM Thread Starter
Yes it don't run at all and my buddy checked it and said it needs injectors but That's why I asked because I'm just not sure
post #5 of 10 Old 06-18-2013, 05:34 AM Thread Starter
I figured 190 was to big
post #6 of 10 Old 06-18-2013, 06:40 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1789 Post(s)
I would bet my next paychexk on the sticks not fixing the no start issue. At least once a month I get to do a fuel system drain and flush because someone put gas in their diesel. You said the ficm is good and all 8 pass buzz so I would lean more to hpo at this point. Especially if it will not fire even one of the cylinders while cranking. The ods that all 8 failed at the same time is almost impossible. Look at your icp pressure and volts while cranking and get back to us.
Originally Posted by kaya View Post
If you follow the sequence to diagnose their issues, and repair them correctly, they're a great engine.
You get what you put in
toren302 is offline
post #7 of 10 Old 06-18-2013, 07:34 AM
PGreenSVT's Avatar
What he said. ^^^
RIP Mitch
the Org crew
post #8 of 10 Old 06-18-2013, 04:17 PM
JustinOOO9's Avatar
Quoted: 584 Post(s)
Garage
there are a few good threads on diagnosing the High-pressure oil pump and system (HPOP) I believe you need at least 500 psi oil pressure to just start these beast and hpop problems are pretty common on these too.
you'll need a god guage set up I think the edge cts or cs or a scanguage will do most of the work for ya.
look into the ICP and IPR valve/ sensors too they can cause no start and help diagnose it further.
Justin,
post #9 of 10 Old 06-18-2013, 07:46 PM Thread Starter
Awesome info guys I will check into it a little further before I buy injectors thank you all!!
post #10 of 10 Old 06-24-2013, 05:47 AM Thread Starter
Well it ended up being the injectors truck runs great
