adjustable cross member or cut and re weld crossmember?? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-16-2013, 09:12 PM Thread Starter
i have a 10 inch lift on my f350 and my front driveshaft wont fit becuase it would hit the crossmember and i dont want to turn down my transfer case.. would anybody recommend and adjustable crossmember or get a shop to cut and re weld it?
03 f350
ARP Studs
Coolant Filter
DC Power inc Alt.
FICM with Reflash
Edge Juice
EGR Delete
Oil Cooler
Fuel Press,EOT,ECT Gauges
40 Inch Toyos
10 inch lift
Straight 4" back with 7" Mbrp tip
LAredneck6.0 is offline
post #2 of 9 Old 06-16-2013, 09:27 PM
ZMANN's Avatar
Quoted: 1670 Post(s)
I was crawling all under mine doing my 4 link with My 8 inch lift
seems like you could just notch where the DS is interfering ?
but mine is an 06 so ?
We Miss you Ronnie
ZMANN is offline
post #3 of 9 Old 06-16-2013, 09:27 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Ill try to save you time and money...clock the transfer case, with that much lift the pinion angle is too great and will cause it to bind and/or wear your u-joints prematurely. Also the front shaft isnt long enough to reach(at least mine wasnt) so i clocked the transfer case as far as it goes before hitting the bottom of the cab and killed 2 birds with one stone. I still am just a hair short when the suspension is at full expansion but when its compressed its fine so as long as i dont let it go all the way up its fine. Then i was hitting the crossmember as well and had them cut it and reweld it around it.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 9 Old 06-16-2013, 09:41 PM Thread Starter
see i had it clocked before.. i didnt like the look of it sticking out under the truck... ive heard of cutting and re welding.. and the shaft i have will reach and the axle ha been turned up some.. is jjust the damn crossmember barely in the way.. and i only need the 4 wheel drive if i need it.. not gonna drive alot with it
03 f350
ARP Studs
Coolant Filter
DC Power inc Alt.
FICM with Reflash
Edge Juice
EGR Delete
Oil Cooler
40 Inch Toyos
10 inch lift
post #5 of 9 Old 06-17-2013, 08:30 AM
layson's Avatar
Quoted: 83 Post(s)
Clock it 20 deg... You won't need to lengthen the shaft if you clock it. I am running a stock front driveshaft at about 14" of lift. Who cares if it hangs down below the frame. You will be able to use your 4x4 without any issues.
Then a few options... you can find a attitude performance crossmember, or I think you might be able to get one from OUO but I don't know if he makes them and it would be worth a phone call or email to OUO, or take your stock one out and have someone modify it.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #6 of 9 Old 06-17-2013, 08:39 AM
Chapter Director
Quoted: 5 Post(s)
Do you have an auto in yours? And if so does the zf6 output shaft sit closer to the cab floor because i was limited to i believe 16 because the other end of the t-case was hitting the bottom of the floor pan at full clock thus making my drive shaft too short at full extension?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 9 Old 06-17-2013, 09:21 AM
layson's Avatar
Quoted: 83 Post(s)
Yes I have an auto. I am not sure on the length for a ZF6. When you build your crossmember you can lower the mount so it pivots at the motor mounts and rotates the motor back. Then your clocked t-case clears and it also makes a little better geometry for the rear. That is one thing that is really cool about the OUO ones, which also makes them spendy. It is adjustable for all of that. The attitude performance one is not adjustable, but I am fairly certain that the same crossmember is used for the ZF6 as the auto.... So I think the attitude performance one probably lowers the tranny mount some.
Quote of the Day:
layson is offline
post #8 of 9 Old 06-17-2013, 09:31 AM Thread Starter
hmmm ...... i have to think on this one..
03 f350
ARP Studs
Coolant Filter
DC Power inc Alt.
FICM with Reflash
Edge Juice
EGR Delete
Oil Cooler
40 Inch Toyos
10 inch lift
post #9 of 9 Old 06-17-2013, 09:43 AM
Chapter Director
Quoted: 5 Post(s)
No im not talking about where it mounts, that can be the same but i mean the distance from the center on the output shaft to the bottom of the floor pan. But oh well it works for me now it would just be nice to clock it just a bit more
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
