Fuel fitting - Ford Powerstroke Diesel Forum
post #1 of 38 Old 06-16-2013, 07:26 PM Thread Starter
617mach 1x's Avatar
Fuel fitting
Can anyone confirmed the earls 6an-12mmx1.5 90* works on the drivers side head without hitting the up pipe??
Sent from AutoGuide.com App
studded, stacked,chipped
trans, turbo, tire and injectors??
617mach 1x is offline
post #2 of 38 Old 06-16-2013, 07:26 PM Thread Starter
617mach 1x's Avatar
http://item.mobileweb.ebay.com/viewi...d=151008676091
post #3 of 38 Old 06-16-2013, 07:35 PM
scparrish's Avatar
Quoted: 85 Post(s)
Feedback Score: 3 reviews
Mine fits just fine no rubbing at all you will be alright
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Turbo, PMF, S&B, Mishimoto rad/ic, 08 axle swap
scparrish is offline
post #4 of 38 Old 06-16-2013, 07:38 PM Thread Starter
617mach 1x's Avatar
Perfect, had a normal 90 on it, didn't work on the drivers side...
Just my luck lol
post #5 of 38 Old 06-16-2013, 07:54 PM
pizza pig's Avatar
I have used these before, work the best.
Earl's 949092 Earl's Big Bore Carb & Fuel Injection Fittings
pizza pig is offline
post #6 of 38 Old 06-16-2013, 07:57 PM Thread Starter
617mach 1x's Avatar
Yea fitting I'm asking about is similar, just goes straight to 6an ss braided line instead of going to 6an flair and another adapter after
post #7 of 38 Old 06-16-2013, 10:01 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
I use the Fittings Greg posted. Generally I always plumb with a fitting to a male -AN and use a female hose fitting. Why would you want the hose to be a permanent part of the fitting? Sound like a PITA to work on and the fitting you are looking at is as expensive as doing it in a more traditional fitting/hose end arrangement.
RIP Mitch
the Org crew
PGreenSVT is offline
post #8 of 38 Old 06-17-2013, 06:15 AM
scparrish's Avatar
Quoted: 85 Post(s)
I thought you were describing what Greg is talking about that is what I used. Either one should work though.
post #9 of 38 Old 06-17-2013, 06:54 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I use the fittings that Greg mentioned on my heads except for the rear driver's side head. My up-pipes hit and would've required serious denting to get to clear. This was also the case on my buddy's truck too. I'm having a set of custom up-pipes made that will clear it because I the banjo fitting I have in there right now is leaking. I absolutely HATE banjo fittings.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #10 of 38 Old 06-17-2013, 09:56 AM
mikeproc is offline
