Installing Fuel Pressure Gauge - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-16-2013, 10:13 AM Thread Starter
Mud digger's Avatar
I'm about to install my FP gauge and was wondering, do I have to connect my sending unit to the regulator test port or can I screw it in to the top of my billet fuel cap (which is already tapped). I know that it will screw in there and that's why it was tapped in the first place but I wanted to make sure that putting the sending unit in the cap it would be as accurate as if I would put the sending unit on the regulator. If anyone has any info on this or have compared the pressures at these two different points that would be great. Thanks
David
2004 F-250 CCSB 4x4- Sinister Coolant filtration system, CCV reroute, 5" Flo-Pro Exhaust with a 6" MBRP tip, SCT Livewire TS
Mud digger is offline
post #2 of 6 Old 06-16-2013, 10:30 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
I always advise using the test port. It is possible for an air bubble to get trapped under the cap which would make your reading from that inaccurate.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 6 Old 06-16-2013, 12:51 PM
Koda22's Avatar
Quoted: 5 Post(s)
Anybody got a picture of this test port? I'd like to install a fuel pressure gauge...
Koda22 is offline
post #4 of 6 Old 06-16-2013, 03:21 PM
USAFBowman's Avatar
The test port is the brass hex head plug near the regulator
USAFBowman is offline
post #5 of 6 Old 06-16-2013, 03:42 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Which way would the reading become inaccurate +/-? Or would the pressure gauge not move because of the air bubble?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #6 of 6 Old 06-16-2013, 09:21 PM
PGreenSVT's Avatar
I suspect it would flutuate wit pressure changes but read low. Fuel is not compressible but the air bubble will compress.
RIP Mitch
the Org crew
