have to ask... again, powermax vs MTW stage1 - Ford Powerstroke Diesel Forum
post #1 of 157 Old 06-15-2013, 03:03 PM Thread Starter
LiftedStroker05's Avatar
i know this has been gone over before.... but iv looked on google and alls i can find is the older "durastroke" cast wheel stage 1 vs the powermax. so what about the newer MTW stage1 w/ billet wheel vs powermax stage1? im torn between the two. the MTW stage 1 w/ '03 billet wheel is $1050 and the powermax stage 1 is $1200 so there isnt much difference. both measure the same (63.8mm IIRC) has anyone ran both? my buddy over at holderdown performance came and did some drag racing with me at the local drag strip. his truck is all stock besides studs, egr delete, powermax stage 1 and 190/30 injectors. he ran a 13.2 in a 6.0 excursion... not to shabby. my plans are very simular except i dont know to go with thte powermax or MTW stage1...
'05 f250 6.0 stroker
ARP studs, Barder fmws468, warren 225/75s,EGR delete, stage 3 hdp trans
4" MBRP to 7" tip,sinister collany system
sct tuned w/ SRL++ xtreme tune
20x12 riots with 420s
Air Dog fp150 w/ 1/2" fuel lines,blue spring mod,
zoodad mod,traction bars
LiftedStroker05 is offline
post #2 of 157 Old 06-15-2013, 04:36 PM
scparrish's Avatar
Quoted: 109 Post(s)
Feedback Score: 3 reviews
Powermax is brand new with no core charge and you can put a billet wheel on it with the money you make off of your factory charger jmo
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Stage 2 Turbo, PHP FICM Tuning, PMF, S&B, Mishimoto rad/ic, 08 axle swap 3.73 gearing
scparrish is online now
post #3 of 157 Old 06-15-2013, 08:12 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 13 Post(s)
powermax with a billet wheel
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #4 of 157 Old 06-15-2013, 08:35 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Stage one hands down.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 157 Old 06-15-2013, 11:17 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
Apparently his truck isn't close to stock...if you asked me. Anyways, his excursion might run well with the P-max and your truck may do better with the MTW. His excursion may even better with the MTW and yours be outrageously fast with the P-max.
No two trucks will perform the same, even with identical add-ons and in this case you're comparing an excursion to a truck (although you didn't really compare anything), you know what I'm getting at. You have to decide what do you think is the best bang for your buck and what are the goals of the truck? Weekend warrior, tow beast or are you looking for best drag strip numbers? There are a lot of variables when deciding on a turbo. Talk to folks that know turbos, explain what your goal is and see what they suggest.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #6 of 157 Old 06-15-2013, 11:40 PM
madpowerstroke's Avatar
Nice looking turbo. I was going to respond on this tread but it was getting to detailed so I started my own thread and put a lot of info on it, it may help you understand things about both the turbos you are asking about.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #7 of 157 Old 06-16-2013, 02:57 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 141 Post(s)
Get the billet wheel in the Pmax. IF you can drop in a ported manifold first the Pmax will shine all day long.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #8 of 157 Old 06-16-2013, 04:42 AM
strokin6L's Avatar
Quoted: 4 Post(s)
MTW stage 1 I believe would out perform the powermax with a billet wheel.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #9 of 157 Old 06-16-2013, 05:25 AM
Slacker
Evil Eye's Avatar
Quoted: 225 Post(s)
Feedback Score: 4 reviews
I've run both with cast wheels and the Stage 1 has better performance and airflow. Now, I can't speak to how they compare with billet wheels, but I've been very happy with my Stage 1.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #10 of 157 Old 06-16-2013, 05:33 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1074 Post(s)
Feedback Score: 6 reviews
I don't have any experience with the Powermax, but the MTW stage1 on the work truck has ben amazing.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is online now
