F550 Motorhome build - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 41 Old 06-13-2013, 02:01 PM Thread Starter
Hello all. I am in the process of picking out parts to improve the performance and fuel mileage on my 2006 F550 based motorhome. Please feel free to comment on my selections. I would also be curious to know where I can find the best prices on these items and how much time it should take to install them. Thanks in advance
Bullet Proof EGR Cooler and upgraded coolant
MBRP 4" Turbo back exhaust (cat delete)
H&S Tuner with Pyro kit and pillar mount
Cold air intake..........????
serpexc is offline
post #2 of 41 Old 06-13-2013, 02:04 PM Thread Starter
Here's a picture of the RV, for size and weight reference.
serpexc is offline
post #3 of 41 Old 06-13-2013, 05:20 PM
Therabbittree's Avatar
The Build depends on how far you want to go to fix it or improve it. Where are you located? Can you delete the egr? the engine check light can be programmed to not come on etc..
I would recommend:
- Gauges, ie - pyro (egt), boost, trans temp, fuel pressure etc.
- A scan gauge II to monitor other stuff ICP, FICM Volts, Oil and Water temp deltas etc etc. You have a full time load, so gauges would be first order.
- SCT tuner and get the custom tunes written for the truck vs a h&s tuner.
- Head studs.
- BPD Oil Cooler, the big Heavy duty Towing version of the cooler
- good 4" turbo back Exhaust
- CCV Mod
Starting Point see what you want and can afford.
Thanks,
Deo
john galt likes this.
Therabbittree is offline
post #4 of 41 Old 06-13-2013, 10:32 PM
There are complete solutions kits for the 6.0 that you can order that will include head studs, egr delete/upgrade and some come with a tuner as well. You can order them from places like river city diesel, xdp and sinister/mkm. I run an Afe stage2si intake combined with the zoodad mod on my F450 and I love it and Im sure its helping fuel economy, I usually see 12mpg city (empty). I've always found good prices on Xdp, plus they have good promotions and sometimes free shipping on orders over a certain amount, so that may be a good spot to look for all of your items. Also, PHP ficm tunes and dieselsites Wickedwheel 2 seem to be very good, simple upgrades. Its worth a google search on those
harrisford is offline
post #5 of 41 Old 06-14-2013, 03:18 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
For what it is worth, H&S isn't the way to go with a 6.0. Stick with SCT and your tuning options are a load broader. That said here we go.
Edge Insight CTS or CS to monitor your engine. Add the EGT probe. Maybe add the backup camera option. Fuel pressure gauge
Delete the EGR if you can where you are.
4" turbo back exhaust with cat delete.
Flush cooling system and run fresh ELC coolant
Get an SCT tow tune for whatever weight you expect to be over a regular 6.0 pickup.
A PHP FICM tune might help as well. Maybe the Economy tune. Any more will raise your EGT's
A BPD heavy duty tow setup is great if you can afford it. Never worry about a clogged oil cooler again but not absolutely necessary.
A Water/Meth injection system to help control EGT's when you are loaded down and have those long grades in front of you. Just spray winter windshield washer fluid when you need it to drop egts. Should drop the 200 degrees maybe 250.
Monitor, monitor, monitor. If you ever need head gaskets do ARP studs with OEM gaskets at that time.
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 41 Old 06-14-2013, 04:24 AM
mattmann86's Avatar
Give quick tricks a call. Vivian is awesome to deal with and she caries a lot of the stuff you will need! Nice rig man!
mattmann86 is offline
post #7 of 41 Old 07-09-2013, 09:17 AM Thread Starter
Thanks for the feedback. I'm pondering just going ahead and installing new head gaskets and head studs now. Is that stupid? I'm not familiar with all of the acronyms for all the different tunes. Just pick one, or are they used in conjunction (stacked)? Also, what's CCV mod? I'm also interested in electric fan options. The stock fan is loud as heck and robs power.......
serpexc is offline
post #8 of 41 Old 07-09-2013, 09:46 AM
Rick C's Avatar
I love that setup...nice rv. Bet they didn't ever think that you might need to pull the cab on that one to replace studs/gaskets...etc...sheesh! Good thing you can do a cab on head gasket job cause that would be hard cab to remove!!! Electric fans aren't worth the money...these trucks allready have too much air flow restriction cause of the grille design. I pretty much agree with what others have said...not that I am any genius or anything.
2005 F-450 CC Fontaine Conversion
(It's the heavy GVW one with the Dana 135, 4:88's and bigger brakes)
Link Air Ride Suspension
Banks Stuff (CAC, Exhaust)
EDGE CTS
SCT x3 with Eric's tunes
Bullitt Proofed (EGR mod, Remote oil cooler/filter, Water Pump, 7.3 fan clutch conversion)
ScanGaugeII
Odyssey AGM's
High Idle Mod, CCV Mod
ARP studs...Finally
More $$$ to be spent i'm sure!
Rick C is offline
post #9 of 41 Old 07-09-2013, 10:08 AM
turbotibbo's Avatar
take it from me do not go the h&s route for tuning , i did and they make great power but as of now they do nothing for the transmission . i had one and switch to sct and its a lot better shifting . if it were my rig i would not mess with the head gaskets until i knew there was an issue . unless money is not an issue . there are lots of custom tuners out there to chose from for the sct . also dp has a new tuner that is made for the 6.0l looks good , i wish i had got one . i would also suggest the blue spring update , coolant filter .there is so much you can do its hard to list it all , i sugesst looking at all the stickies in the general 6.0l section and read up on what to monitor ......good luck ...ill be waiting for pics and details ....lol
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #10 of 41 Old 07-09-2013, 10:38 AM
Arctic Fox's Avatar
Quoted: 9 Post(s)
Feedback Score: 8 reviews
No one makes an electric fan that moves as much air as the stock fan.
That said... some guys are running electric fans and getting away with it, but I wouldn't do it on a truck (or motor home) that is going to be hauling/towing max GVWR.
The only stacking of tunes on a 6.0 is running a FICM tune along with a ECM tune (SCT with tunes of your choice).
In your case I would only recommend a mild (maybe moderate) FICM tune and then some towing tunes for the SCT, get a trans only tune for when you tow near max GVWR and another towing tune with some added power for when you are towing under 8k.
2006 F-450 XLT 4x4 Auto 4.30L Alcoa 19.5" 16,000 GVWR
Kelderman 4-Link/4-Bag Rear Suspension, Lariat Seats, '08 Console, '11 Mirrors, CTS, SCT X3
ARP's w/OEM HG, BPD 6ph FICM @ 58v, BPD Oil Cooler w/stat, Ported Intake, 185 amp Alt
P-Max w/WPE billet wheel, Spearco IC, 4" Banks Exhaust, Shell T6, Zerex EC-1, Oil bypass filter
50,000 miles
Arctic Fox is offline
