EGT probe - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-22-2008, 09:53 AM Thread Starter
surfdunn's Avatar
EGT probe
Does it matter if I put it on the top or on the bottom of the manifold. Looking to start drilling soon and it doesnt look very fun if I go through the top. Any suggestions?
2006 FX4 F250 supercab shortbed, MBRP turbo back w/muffler and CAT delete, SCT Xcall 3 w/ Innovative tunes, CFM Shorty, autometer sport comp II guages,bottle in the back seat. hybrid Turbo, Fass Fuel System 95/180, Swamp 170 injectors, FCDP full EGR delete
Only Tuned By the Best. Innovative Diesel
1999 F150 supercab shortbed , triton 5.4, AEM intake, Mac 78mm throttle body, 33" BFG mudterrains, 3"performance accersories bodylift
surfdunn is offline
post #2 of 11 Old 03-22-2008, 10:05 AM
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
I haven't done it so i cant help by experience, but from what ive read it wont hurt drilling from the bottom, might actually be better because less shavings will go into the manifold.
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #3 of 11 Old 03-22-2008, 10:34 AM
stroken04's Avatar
I have never heard of doing it from the top,
check out this link-http://www.powerstroke.org/forum/6-0-mod-help/9139-egt-probe-placement.html
this is where i did mine
stroken04 is offline
post #4 of 11 Old 03-22-2008, 10:55 AM
bigwhite6oh's Avatar
that link is where i put mine as well...
Diesel Manor also has a great write up for wiring and everything you need to know about installing an EGT, Boost, and Tranny Temp gauge
2003 F350 6.0 PSD
\\CC//LB\\SRW//
Silverline Cat-Less Dual Turbo Back | Innovative Tuned X3
| S&B Intake | Autometer GS series Boost/Pyro gauges | Billet grille, IPCW ultra-clear clearance lights | LED bulbs for all | external lights | Recon White Lightning | LUND SunVisor | Fog Light Mod | High Idle Mod | Zoodad Mod | CCV Re-routed | Pioneer AVIC D3 | Alpine Type S/Rockford 3way speakers | Rockford 4 Channel Amp
bigwhite6oh is offline
post #5 of 11 Old 03-22-2008, 11:45 AM
pinkfloyd's Avatar
Send a message via MSN to pinkfloyd
I wouldn't put it on the top unless the manifold is off the motor reason being that the shavings will drop into the manifold and then your screwed. drill from the bottom then the shavings will drop down out of the manifold.
2002 f-250 4X4 XLT 7.3,
stock tranny
DP-Tuner F6 chip
mbrp ss 4" turbo back exhaust
diy intake with zoodad mod
3 pilllar guage setup with autometer guages Thanks Raul
valve body
boost fooler
NEXT ON LIST
torque converter
pinkfloyd is offline
post #6 of 11 Old 03-22-2008, 11:58 AM
bfloyd4445's Avatar
Quoted: 3 Post(s)
No. But the thermocouple should go where it can get a mixture of the exhaust from all cylinders. The one photo posted here looks to me like it was installed to read only the temp of one cylinder. All cylinders do not run at the same temperature all the time and what your interested in is the effective average temperature of all cylinders not just one cylinder.
Britt
2007 F250 CC SB 4X4, SB, PSD, Lariet, stock
1975 Ford 2000 ROP Diesel tractor < ran without oil for 2/10 mile 7/12/2009> Stills runs as good as ever
"If you don't read the newspaper you are uninformed,
If you do read the newspaper you are misinformed."
-Mark Twain
bfloyd4445 is offline
post #7 of 11 Old 03-22-2008, 12:22 PM Thread Starter
surfdunn's Avatar
thanxs guys just drilled it from the bottom and everything is good. thanxs for the help again
surfdunn is offline
post #8 of 11 Old 03-22-2008, 12:23 PM
Glad to see you are installing your gauges Brandon! When is the next day at the track?
720Deere is offline
post #9 of 11 Old 03-22-2008, 12:47 PM
Rice Hunter
Diesel Freak's Avatar
I drilled mine on the bottom rear of manifold. I ran engine while drilling for little more insurance reasons. WEAR SAFETY GLASSES!!
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #10 of 11 Old 03-22-2008, 01:14 PM
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
I wouldn't run the engine when drilling it, what if there is a few bigger shavings or you snap the drill bit off, its gonna go right into the turbo. Id leave it off then once i drill it, stick a small magnet in there to get most of it out, and shop vac it out too. Just my opinion.
BPS President
Jake is offline
