"Daddy's wallet" build!! - Ford Powerstroke Diesel Forum
post #1 of 128 Old 06-12-2013, 05:07 PM Thread Starter
617mach 1x's Avatar
Ok well, some may have notice I've been asking all kinds questions lately!
Talked with Greg, Nate, Matt, Frank and a few others
Ok, about me, I'm 21 work full time at my dads shop, bought the truck it mines and no he's not paying for any of this, we got the name cause technically it does come out of his wallet since he pays me, and was a joke running with the neighbour
Build specs,
4in intake
Ported intake manifold
Gaskets (again)
190/75 or 100
66/68/.83
My own up pipes
My own headers
Fuelab 41401 pump
Fuelab 52901 regulator
Traction bars, wheels, tires and 2nd set of shocks up front to
Goals 550-600hp
I have a spare motor, trans, transfer case and axles
"Daddy's wallet" build!!-imageuploadedbyautoguide1371085555.275125.jpg"Daddy's wallet" build!!-imageuploadedbyautoguide1371085576.802632.jpg"Daddy's wallet" build!!-imageuploadedbyautoguide1371085598.202796.jpg"Daddy's wallet" build!!-imageuploadedbyautoguide1371085616.369333.jpg"Daddy's wallet" build!!-imageuploadedbyautoguide1371085636.219579.jpg
Sent from AutoGuide.com App
studded, stacked,chipped
trans, turbo, tire and injectors??
617mach 1x is offline
post #2 of 128 Old 06-12-2013, 05:10 PM Thread Starter
617mach 1x's Avatar
"Daddy's wallet" build!!-imageuploadedbyautoguide1371085696.852809.jpg"Daddy's wallet" build!!-imageuploadedbyautoguide1371085711.652629.jpg"Daddy's wallet" build!!-imageuploadedbyautoguide1371085723.619452.jpg"Daddy's wallet" build!!-imageuploadedbyautoguide1371085743.802833.jpg
post #3 of 128 Old 06-12-2013, 05:16 PM
turbotibbo's Avatar
sweet , ill be watching this one
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #4 of 128 Old 06-12-2013, 06:16 PM
william_ace's Avatar
Quoted: 2 Post(s)
Me as well. This looks pretty cool. How do you feel the non vgt turbo will be compared to a vgt turbo off the line?
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #5 of 128 Old 06-12-2013, 08:34 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
In........
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #6 of 128 Old 06-12-2013, 08:38 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
I can't wait to see how you design your headers... Subscribed
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #7 of 128 Old 06-12-2013, 08:45 PM
JustinOOO9's Avatar
Quoted: 521 Post(s)
Garage
interested in seeing what number the headers alone will add. I see around 20hp for long tube headers with free flowing exhaust on gassers all the time.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #8 of 128 Old 06-13-2013, 12:51 AM
King Rancher_27's Avatar
subscribed
-Casey
2012 F250 FX4 stock with 3.55 gears
2006 F250 King Ranch FX4--SOLD
ARP Studs-OEM gaskets(this time
SCT with IDP tunes,Gearhead tunes & TSD TUNES
EDGE CTS insight
5" TB with 6" Tip no kitty or muff
Sinister Delete Kit
Upgraded oil cooler
leveled w/ 295/70/18 Nitto Trail terrian
6.4 banjo bolts
Blue Spring Upgrade
KC Stage 3 68mm Turbo
Ported Intake
S&B CAI
190/75 Renagade injectors
STC fitting
King Rancher_27 is offline
post #9 of 128 Old 06-13-2013, 01:50 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Very cool!
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #10 of 128 Old 06-13-2013, 01:57 AM
RidinHigh's Avatar
Quoted: 8 Post(s)
subscribed
2013 F250 6.7- some stuffs missing, some added.
RidinHigh is offline
