Wicked Wheel? - Ford Powerstroke Diesel Forum
post #1 of 160 Old 06-11-2013, 04:50 PM Thread Starter
superBADduty's Avatar
Quoted: 17 Post(s)
Garage
Wicked Wheel?
I'm going o remove my turbo to change the up pipe (has a crack in the bellows).
Figure it would be a good time, if I was going to change, to put the Wicked Wheel in.
Does anyone have any input on whether or not its worth it, or if there is another option other than changing turbos.
Thanks
2007 F250 KR CCSB 4x4 ARP's, PMM's EGR delete, PMM's coolant filter, SCT Sf3, GearHead's SRL & SRLXX, Rancho 7000's, IDP FICM tuning, blue spring, Wicked Wheel 2, No Limit Fab. CAI., 2008 rear differential cover.
2006 GMC Savanna 3500 6.6 LBZ Duramax work van
2008 F250 KR CCSB 4x4 quad buckets minimax "SOLD"
superBADduty is offline
post #2 of 160 Old 06-11-2013, 06:52 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1685 Post(s)
I did the XS Boost wheel in mine and have no regrets...In fact love it. Lower EGTs faster spool and better throttle response.
I can sum it up this way. I have spent way more than 200.00 that didnt even come close to giving me the seat of the pants gain this wheel has. So I would say yah its worth it. Only regret is not getting the MTW wheel. I still might pick up a single plane one to try tho.
toren302 is offline
post #3 of 160 Old 06-11-2013, 07:18 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Got any pics of the xsboost wheel??
We have the wheels in stock if interested. They have shown to reduce EGTs by at least 50F (some have reported as high as 200F drop but I don't advertise that you'll see that) and provide a noticeable (not earth shattering but enough to feel) difference in power in the lower to mid RPM range. This is as well as slightly quicker spool and throttle response. Hope it helps.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #4 of 160 Old 06-11-2013, 07:45 PM
turbotibbo's Avatar
Thanks
I have a mtw wheel for my 03 turbo and its a nice upgrade if you are looking to lower egts and a bit more power .
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #5 of 160 Old 06-11-2013, 07:52 PM
Bump To Pass!!
toren302's Avatar
Sure do. I might be PM'n you one one.
toren302 is offline
post #6 of 160 Old 06-11-2013, 07:59 PM
BACKYARDIGAN
Quoted: 4 Post(s)
Cool. Thanks man. It's hard to tell from the pic how tall it is. And I'm not sure if matters or not as I haven't tested both wheels to see if there is a difference. I know our billet wheels are significantly taller than the OEM wheel, which I found interesting.
Nate
post #7 of 160 Old 06-11-2013, 08:02 PM
Bump To Pass!!
toren302's Avatar
I belive they have the specs on the site it is taller but I dont know by how much. You guys do offer a single plane for the 03 right?
toren302 is offline
post #8 of 160 Old 06-11-2013, 08:14 PM
BACKYARDIGAN
Quoted: 4 Post(s)
No not as of yet we don't. We may in the future, but aren't sure yet.
Nate
post #9 of 160 Old 06-12-2013, 12:19 PM
WHO SELL THIS WHEELS AND HOW MUCH
JOHNNYBUSA is offline
post #10 of 160 Old 06-12-2013, 01:17 PM
BACKYARDIGAN
Quoted: 4 Post(s)
We at MTW sell a drop in replacement billet wheel for the 6.0 OEM turbo. We don't call it the Wicked Wheel or anything as that is trademarked by DieselSite. They sell theirs for $239 plus shipping and we sell ours for $230 shipped. We also have wheels for the 03 turbos as well as the 04.5-07 turbos where theirs are only for the 04.5-07 turbos. Hope this helps.
Nate
