modifed intake manifold owners - Ford Powerstroke Diesel Forum
post #1 of 21 Old 06-11-2013, 03:15 PM Thread Starter
Lt. Negativity
RescueF250's Avatar
Lightbulb modifed intake manifold owners
Im curious anyone that has a modified manifold that has the egr and coolant passage cut out, how are you running your line off the oil cooler ? And what sizes did you go with ? And routed where ? Also how are your ect and eot readings ?
Matt at Gearhead,Doug at GoGo,Dave at Diesel Innovations,Ryan at Full Force Diesel,Eric at Innovative. Adam at First Coast
Built 2003 with 04.5-07 parts,Hey its a hybrid
Totaled
New Era Rescue 08 F250 CC/SB No limit stuff, H&S stuff, Fl pro stuff.
RescueF250 is offline
post #2 of 21 Old 06-11-2013, 03:51 PM
Snake's Avatar
Quoted: 46 Post(s)
I think you already have the specs on the Gogo Stage 1.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #3 of 21 Old 06-11-2013, 06:16 PM Thread Starter
Lt. Negativity
RescueF250's Avatar
Yup myself n brian have figured out the issue as well that we have noticed. But the lack of commenting im gonna guess ppl either dont know they have an issue or already know
Totaled
post #4 of 21 Old 06-11-2013, 06:30 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
THIS IS WHAT I DID!
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #5 of 21 Old 06-11-2013, 06:54 PM
powerstrokecrzy's Avatar
Quoted: 256 Post(s)
Originally Posted by JUGERNAUT View Post
THIS IS WHAT I DID!
Uhhh, details please!! Sizes, actual parts, does it fit under the intake with no problem? Looks like a great idea, I left the egr part on mine because I had read that you couldn't get sufficient coolant flow any other way. I may do this to mine when after I install the one I'm working on now.
Thats if you don't mind sharing of course
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #6 of 21 Old 06-11-2013, 07:14 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
He's going to be running a 6.4 manifold that is modified to run on a 6.0. You can't fit that stuff under a 6.0 manifold without some serious modification.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #7 of 21 Old 06-11-2013, 07:20 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
I run from the stock egr coolant fitting on the oil cooler to the heater return line under the degas bottle with 3/4 hose.
RIP Mitch
the Org crew
PGreenSVT is offline
post #8 of 21 Old 06-11-2013, 07:27 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Do what Mitch says you will be fine!
A/C ASW A/W WINGS
post #9 of 21 Old 06-11-2013, 07:33 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
I have a 6.4 manifold on mine and it blocks the coolant return on the front cover. I also have a BPD oil cooler so I used a 1/2" pipe plug in the BPD block that plugs off the coolant flow there. Can anyone say $0.50 EGR delete kit?? LMAO.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #10 of 21 Old 06-11-2013, 07:38 PM
Arctic Fox's Avatar
Quoted: 9 Post(s)
Feedback Score: 8 reviews
Currently I have a BPD oil cooler and the GoGo intake manifold.
Instead of plugging the water outlet on the BPD transfer block but I decided to run it back into the degas bottle to help with purging air from the system.
But when I first installed the GoGo intake I still had the OEM oil cooler and was using the supplied GoGo modified water outlet with a 3/8" hose returning the water from the oil cooler to the degas bottle. That was when I first had issues with ECT/EOT deltas, before the GoGo manifold I had a 5 degree delta and right after installing it the delta went up to 20 degrees. I was pretty sure the reduced water flow through the oil cooler had caused the increase in oil temps so I experimented with some tee's in the water return, running it into both of the small ports on the degas bottle which reduced the delta by 3 or 4 degrees. Also the return port on the degas bottle has a very small I.D. of about 3mm which I drilled out to 5mm.
I definitely agree with what Mitch did using the 3/4" hose to return the water
Not long after that I installed the BPD oil cooler and haven't looked back.
2006 F-450 XLT 4x4 Auto 4.30L Alcoa 19.5" 16,000 GVWR
Kelderman 4-Link/4-Bag Rear Suspension, Lariat Seats, '08 Console, '11 Mirrors, CTS, SCT X3
ARP's w/OEM HG, BPD 6ph FICM @ 58v, BPD Oil Cooler w/stat, Ported Intake, 185 amp Alt
P-Max w/WPE billet wheel, Spearco IC, 4" Banks Exhaust, Shell T6, Zerex EC-1, Oil bypass filter
50,000 miles
Arctic Fox is offline
