need egr delete kit installed - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-10-2013, 09:58 PM Thread Starter
I have a 2005 ford f350 single rear wheel that i need to find someone in the jacksonville florida area to install a egr delete kit and oil cooler kit on. Any help on who to take it to would be greatly apreciated the lowest estimate i have gotten so far is around $1900.00 which seems a little high to me thanks.
1999 f250 diesel is offline
post #2 of 14 Old 06-10-2013, 10:02 PM
turbotibbo's Avatar
would you ever consider doing the install on your own , its a straight forward job takes about 8 hrs or so but I would take a weekend to do it. easy
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #3 of 14 Old 06-10-2013, 10:10 PM Thread Starter
Yeah i no i can do it i just dont have the extra time rite now and am scared to start towing heavy with it before i have it done. Will a programmer that just turns the valave off help at all before i delete it. I am just not real familiar with the 6.0 i have always had the reliable 7.3
post #4 of 14 Old 06-10-2013, 10:14 PM
turbotibbo's Avatar
as long as your egr cooler and oil cooler are healthy you are not really hurting the truck by towing with an egr system intact. its when the cooler ruptures when u need to worry so people get rid of it to prevent problems , also the valve can get gummed up and the valve will stick open . a tuner can turn the valve off but the cooler is still there and if your oil cooler is pluged up it will not be long before the truck is puking . do u have a monitor
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #5 of 14 Old 06-10-2013, 10:18 PM
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
in jax.. there is only one place to go... thats First Coast Diesel Performance... look em up and talk to Adam!... they are great guys
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
post #6 of 14 Old 06-10-2013, 10:23 PM Thread Starter
what do u mean monitor. Yeah im familar with them they had the cheapest price so far.
I just dont see almost 1500 dollars in labor for 8 hours work.
post #7 of 14 Old 06-10-2013, 10:25 PM
turbotibbo's Avatar
the first thing you should buy even befor you buy a 6,0l is a monitor, some thing to read eot , ect ficm voltage ect....Write Up: Monitoring the 6.0L PSD.
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #8 of 14 Old 06-10-2013, 10:30 PM Thread Starter
no i dont have a monitor
post #9 of 14 Old 06-10-2013, 10:33 PM
turbotibbo's Avatar
it would be a great start to making your 6.0l reliable , hope this helps
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #10 of 14 Old 06-10-2013, 10:35 PM Thread Starter
thanks or ur time.
