Which Tuner? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-10-2013, 05:02 PM Thread Starter
Which Tuner?
Hey guys I am looking for a tuner thAt also displays gauges. Which as the good ones out there. I heard bulldog burns out the the transmission and I need a tuner that can also turn off the check engine light due to the egr delete. Lmk what u guys think. I was looking at the sct livewire
Sent from AutoGuide.com App
darren808 is offline
post #2 of 12 Old 06-10-2013, 06:29 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
SCT Livewire TS, with custom tunes.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 12 Old 06-10-2013, 06:34 PM
turbotibbo's Avatar
yes sct is the way to go , also dp tuner has a neat tuner that is made for a 6.0l and they custom tune as well
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #4 of 12 Old 06-10-2013, 08:12 PM Thread Starter
Oh ok cool. So the sct livewire will take care of the egr delete check engine light?
post #5 of 12 Old 06-10-2013, 08:13 PM
turbotibbo's Avatar
it sure will
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #6 of 12 Old 06-10-2013, 08:19 PM
JustinOOO9's Avatar
Quoted: 521 Post(s)
Garage
I use the sct sf3 for tuning and the edge cs for guages. nice combo. the sct can remove the egr light. the edge cs can also read codes, you can do your own 1/4 mile test and download results to laptop etc... the livewire is just too big n bulky for me.
sct for tuning
edge cs or cts for guages hands down.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #7 of 12 Old 06-10-2013, 08:21 PM Thread Starter
I like the fact that it push on the fly though.
post #8 of 12 Old 06-10-2013, 08:32 PM
turbotibbo's Avatar
I don't think the live wire has shift on the fly tuner?
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #9 of 12 Old 06-10-2013, 08:36 PM Thread Starter
In that case that sucks. That's what I am looking for. What do u guys recommend on shift on the fly tuners with gauges?
post #10 of 12 Old 06-10-2013, 08:37 PM Thread Starter
Also taking care of the egr delete check engine light.
