Need some advice please - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-10-2013, 01:19 PM Thread Starter
King Rancher_27's Avatar
Well Ive been on the fence for a while about maybe changing my wheel out in my Powermax. Since i put my 190/stock injectors and had Eric rewrite my tunes and also bought new tunes from Gearhead (which are great) my question is would changing the wheel out help with egt's or would i be better off getting another turbo and sell mine. Ive had the powermax for under 20,000 miles and i know a few people that would like to have it for a buget build. Next would it be worth getting water/meth injection? Running @70 egts are @ 750-780 wot 1450 for a second and i get out of it. Its controllable but annoying at the same time. For my last question, being since im able to do the work myself, would it be worth building my own transmission with better parts? This is my DD and i pull some but nothing more than 10k-12k and my boat is @3,500lbs....
Sorry for the long post but ive been reading a lot and cant really find the answer i want or need.
Thanks in advance,
Casey
-Casey
2012 F250 FX4 stock with 3.55 gears
2006 F250 King Ranch FX4--SOLD
ARP Studs-OEM gaskets(this time
SCT with IDP tunes,Gearhead tunes & TSD TUNES
EDGE CTS insight
5" TB with 6" Tip no kitty or muff
Sinister Delete Kit
Upgraded oil cooler
leveled w/ 295/70/18 Nitto Trail terrian
6.4 banjo bolts
Blue Spring Upgrade
KC Stage 3 68mm Turbo
Ported Intake
S&B CAI
190/75 Renagade injectors
STC fitting
King Rancher_27 is offline
post #2 of 6 Old 06-10-2013, 06:43 PM
turbotibbo's Avatar
to be honest the egts you describe don't seem out of control at all . if it were me I would get the wheel and if you don't like it sell the turbo with the wheel . I don't have a powermax but I installed a mtw billet wheel on my 03 turbo and it lowered egts around 50-70 when crusing and 90-190 on wot runs . I was happy with the new wheel . mabey some one with a powermax will chime in
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #3 of 6 Old 06-11-2013, 08:25 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
If your funds allow you too, I would consider a MTW stage 3. Adrain is doing some amazing tweaks with his turbos, you will not be disapointed. That seems to be a great combo. But I'm positive your trans is on borrowed time.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 6 Old 06-11-2013, 09:49 PM Thread Starter
Thanks for the replys. Ive been reading up on that turbo as well but im thinking i need to concentrate funds to the trans. Im trying to find the parts to do it but not having to much luck. Im not sure what kind of Hp im putting down yet cause its a good drive to use a dyno. I know if i run a 1/4 mile on my edge i hit 91 mph @ 14.7 sec
-Casey
EDGE CTS insight
Sinister Delete Kit
Upgraded oil cooler
6.4 banjo bolts
Blue Spring Upgrade
Ported Intake
S&B CAI
STC fitting
post #5 of 6 Old 06-12-2013, 06:06 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Suncoast has the parts to build your trans as does PATC. Our Supporting Vendor SAP Performance is a reseller for PATC. So do ATS and Elite Engineering.
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 6 Old 06-12-2013, 08:17 AM Thread Starter
Thanks! Ill do some looking into that tonight at work.
Sent from AutoGuide.com App
-Casey
EDGE CTS insight
Sinister Delete Kit
Upgraded oil cooler
6.4 banjo bolts
Blue Spring Upgrade
Ported Intake
S&B CAI
STC fitting
