boost ? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-10-2013, 11:22 AM Thread Starter
ssdeuce's Avatar
boost ?
hey guys I've noticed my boost is going to 28 then bounces a bit like 26-28 at wot. would this be a sign of a leak or maybe the ebp sensor being dirty. I did the head studs last summer and everthing checks out good and tight so I don't think it's a leak. I did have all the latest strats put in a few months ago, maybe that has something to do with it cause I used to hit 30-32 with the idp ficum tune but thought it hurt the mpg so I got it flashed by ford.
I MAY BE CRAZY BUT I AIN'T DUMB
04 F250 6.0 FX4 CC SB
S&B intake
CFM+ INTAKE ELBOW
4" TURBO BACK STRIAGHT PIPE NO CAT
SCT W/ VIVS TUNES
ZOODAD MOD
SUPERCHIPS DUAL LAZER GAUGE (EGT&BOOST)
ford blue spring
banjo bolts
and heck its my slowest vehicle
gotta work on that
ssdeuce is offline
post #2 of 5 Old 06-10-2013, 11:38 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Yep the latest flash is what did it. I don't think you have a boost leak.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 5 Old 06-10-2013, 11:45 AM Thread Starter
ssdeuce's Avatar
good thing it was free, php rollback and ficm tunner coming up next. course this was all with the looney and agg tow from viv.
S&B intake
CFM+ INTAKE ELBOW
SCT W/ VIVS TUNES
ZOODAD MOD
ford blue spring
banjo bolts
gotta work on that
ssdeuce is offline
post #4 of 5 Old 06-12-2013, 09:53 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
You might run your looney tune before you jump to conclusions, although the new strategy codes are know for decreasing mileage.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 5 Old 06-13-2013, 06:45 AM Thread Starter
ssdeuce's Avatar
I am running my looney, I switched to looney wild last night, I like it ALOT. I do want to try an old strat tune just to compare, definately doing the ficm tune. Thats were I lost 4 psi boost im sure cause thats when it dropped.
S&B intake
CFM+ INTAKE ELBOW
SCT W/ VIVS TUNES
ZOODAD MOD
ford blue spring
banjo bolts
gotta work on that
ssdeuce is offline
