Stock HFCM as lift pump or vice versa? - Ford Powerstroke Diesel Forum
post #1 of 39 Old 06-10-2013, 06:10 AM Thread Starter
I know Juggernaut had success with a 6.4 HFCM as a lift pump. My question now is, could the same results be yielded with the stock 6.0 hfcm?
When I put the ****ty ad2 on I completely removed the stock HFCM (I left the wiring harness) and since then I POS ad2 has gave out. Either that or use the ad2 as a lift for the stock HFCM?
2005 Lariat 6.0
4" TB exhaust to 6" tip
Tuned by the Wildman
Warren 190's
AD2 sumped
Studs and gaskets
EGR delete
CCV/Zoodad
Blackcloud413 is offline
post #2 of 39 Old 06-10-2013, 06:19 AM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
You could use the AirDog as a lift pump for the stock HFCM, or a 6.4 HFCM as a lift pump for the stock one.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #3 of 39 Old 06-12-2013, 09:50 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I've never heard of this, I know what I'm reading about tonight. Thanks
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 39 Old 06-12-2013, 10:42 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
Dale is currently using a 6.4 HFCM to feed his AD2. I'm currently building a fuel system around a 6.4 HFCM feeding the 6.0 HFCM. I have the 6.4 pump in my room with all the other fuel system goodies I have.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #5 of 39 Old 06-13-2013, 09:52 AM
Quoted: 5 Post(s)
That turbo looks pretty shack - is that powder or paint?
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #6 of 39 Old 06-13-2013, 10:57 AM Thread Starter
I've been looking for a 6.4 pump, but everyone wants an arm and a leg for em...
2005 Lariat 6.0
Warren 190's
AD2 sumped
Studs and gaskets
EGR delete
CCV/Zoodad
post #7 of 39 Old 06-13-2013, 12:02 PM
Quoted: 10 Post(s)
Duplicolor metal cast blue anodized paint with their high temp clear...lots of it.
Depends on what you consider an arm and a leg. I got mine at a wicked deal but you can find them all day long on ebay for 150-200. That's cheaper than an AD100 lift pump.
Shack
post #8 of 39 Old 06-13-2013, 01:34 PM
Quoted: 8 Post(s)
What psi does the 6.4 run at?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #9 of 39 Old 06-13-2013, 01:35 PM
Quoted: 10 Post(s)
10-12. It's a low pressure high volume pump whereas the 6.0 pump is a low volume high pressure. The 6.0 pump is capable of 100psi.
Shack
post #10 of 39 Old 06-13-2013, 02:04 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
sometimes them 6.4 pumps fall out of the sky
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
