I want to build 225 Injectors - Ford Powerstroke Diesel Forum
post #1 of 23 Old 06-10-2013, 05:00 AM Thread Starter
twoicebergs's Avatar
Quoted: 47 Post(s)
Well, actually I don't, but I have been getting a lot of PMs about what it takes to build larger ones. I keep hearing the fuel metering is improved, but to set the record straight, what is being done to build conventional injectors larger that 200cc?
The intensifier piston and plunger cuts are easy to figure out, but what is being done to the other internals? What holes are being enlarged? Is the BB different? Is the fuel plate being shaved? Lastly, are different springs being used with the plunger?
Barring someone laying out the changes, if someone is willing to donate a grenaded larger injector or measure a 225 or larger and report back, please do.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #2 of 23 Old 06-12-2013, 09:20 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Subscribing...
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 23 Old 06-13-2013, 05:59 AM
pizza pig's Avatar
You shim the body at the fuel plates.
pizza pig is offline
post #4 of 23 Old 06-13-2013, 07:27 AM Thread Starter
Quoted: 47 Post(s)
Thanks for responding.
So what you are saying is that nothing is different to the metering plates or holes in them to supply more fuel to the bore? I could see what you are saying working if the port wasn't plugged, but what would need changing, if anything, if the spill port was plugged?
Frank
Working for Toys
post #5 of 23 Old 06-13-2013, 07:03 PM
Quoted: 8 Post(s)
I know that if the spill ports are plugged you can experience at rough idle. Why don't 205cc and up injectors come with the spill ports unplugged? Correct me if I'm wrong but when they are plugged it allows more fuel to be stored increasing the cc, right? Basically is it making it cheaper to get more cc out of an injector?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #6 of 23 Old 06-14-2013, 03:20 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
A 190-200 cc injector is about as big as you can go and still keep the spill ports un-plugged, because there just isn't anymore usable volume than that from the spill ports to the end of the body.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #7 of 23 Old 06-14-2013, 05:14 AM Thread Starter
Quoted: 47 Post(s)
The issue to discuss isn't fuel plate spacers or spill port plugging to create larger usable chamber volume, except if it affects what has to be done to the injectors to ensure enough fuel is available at the top of the injection stroke. For anyone who missed it in any other threads, plugging the spill ports gives the equivalent of 20cc increase in injector sizing. Obviously the plunger return spring will aid in drawing fuel into the chamber, but at some point there may be other issues on ensuring enough fuel is available. Who knows, maybe nothing is required until you are completely rebuilding the cores for massive injectors or hybrids.
If someone wants to PM me with the info, your name will remain anonymous.
Frank
Working for Toys
post #8 of 23 Old 06-14-2013, 09:44 AM
well i have 175cc injectors i built and mine loped a little at idle.but i think the
reason was air in the system plus i half a**ed it with the o-ring kit and cw's and
now i am paying for it.what is the most one could take off the int. piston and still be ok
or the shaft.i havn't done it yet but i think there is plenty of material there to get 225cc inj.
can some pm me and explain about the fuel plates.great post frank i know you will figure it out bud.
fatbastardf350 is offline
post #9 of 23 Old 06-14-2013, 10:52 AM
617mach 1x's Avatar
Frank I have 6 injectors waiting for you to figure this out haha
Build me anything 225-285cc
We could always buy a used 225-285 for measuring??
Sent from AutoGuide.com App
studded, stacked,chipped
trans, turbo, tire and injectors??
617mach 1x is offline
post #10 of 23 Old 06-14-2013, 11:03 AM Thread Starter
Quoted: 47 Post(s)
For 225s from 175s you would need to take off another 0.063" or add spacers to give the equivalent. For every .010" off, you get about 8cc equivalent. 275s would be another 0.063". The problem is still how to ensure you get the fuel in the chamber. Plus as you get larger you may be putting stress on the return spring.
Frank
Working for Toys
