Best non-studded tune? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 06-08-2013, 04:31 PM Thread Starter
I've read alot about innovative diesel and vivains tunes. I just purchased the SCT live wire 5015 to tune and help keep an eye on what the engines doing. Right now my truck (03 f-350 with 48,000 miles) currently has a 4 inch turbo back exhaust, Zoodad mod and thats it. I plan to get it studded but it'll be next summer for this poor collage kid. Egr delete is next on my list. But anyways back to my question! What tune should I run?? Innovatives Extreme street as my DD tune / The economy tune for traveling. With the Extreme X for when that pesky D-max owner wants to throw down. Or run one of Vivians tunes? I've read thru a fair amount of the forums info on tuners and skimmed the surface on tunes (very helpful) but Hopefully some one can help me pick the right ones!
Thanks! Long time reader first time posting on the forum
YamahaAwesome is offline
post #2 of 19 Old 06-08-2013, 05:07 PM
call innovation and talk to them never had a problem with there tunes. I run the non studded looney and like it.
03 f-250
blue spring
4inch turbo back exhaust
egr delete
MTW HYBRID
SCT livewire
scan gauge w egt
zoodad mod
fuel press gauge
225,000 miles
155/stock holder diesel
tatertot is offline
post #3 of 19 Old 06-08-2013, 05:18 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
For a truck with factory bolts I recommend Matt Robinson from gearhead automotive. I ran his SRL for 2 1/2 years without any issues and I ran the crap outa my truck too!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 19 Old 06-08-2013, 10:24 PM
Gapowerstroke's Avatar
I'm running Erik's xtreme street tune from innovative. Truck is strong down low and up high. No issues with about 15k on it.
06' F250 CC SR SB FX4 AT
Studs,S&B CAI, MRBP 4" exhaust 3.5" down pipe, SCT LIVEWIRE TS, Tuned by Eric (xtreme street and race), Innovative Inductive and Performance FICM Tunes, blue spring upgrade, 2.5" Carli Leveling kit, 18x9 BMF Novakane Death Metal with 35x12.50 Toyo MT's 3:73 gears.
Gapowerstroke is offline
post #5 of 19 Old 06-09-2013, 03:01 AM
JustinOOO9's Avatar
Quoted: 578 Post(s)
Garage
until you get studs with a personal opinion just use the tow 50+ hp unless you got money set aside... the factory bolts are so flip floped on reliability.... mine stretched at 52k some have never had a problem... but the aggressive timing is what gets these non-studded trucks. high hp tunes = aggressive cylinder timing
could happen over night could never happen your risk should be determined by pocket book size till you get all the parts you need.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s, JW Vbody.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is online now
post #6 of 19 Old 06-09-2013, 03:17 AM
What tunes/tuner were you running? Erik's non studded tunes keep cylinder pressures in check. I also have his xtreme race non studded tune and have no issues running it except a little more heat and less fuel economy. Also running their hot ficm tune but those are also safe on stock bolts.
post #7 of 19 Old 06-09-2013, 10:47 AM
JustinOOO9's Avatar
Quoted: 578 Post(s)
Garage
I was really new to diesels esp the problems of the 6.0... so I was going stock no tunes, no guages etc... then about 6 months after i bought it i had some coolant resdue on my cap so I reduced the coolant fill lvl and got a new cap. seemed to work for few weeks then puked a little more. so had a mechanic that sinister diesel reccommended due a coolant pressure test static/ driving etc... 21.5psi... so i got arps, egr delete, new oil cooler and i did the vc-9 flush before hand etc... and switched to cat elc coolant. now i run stock maybe a trans only tune once in a while for the check engine light.... anyone know why my 04 model has the code after egr delete thought they weren'tsupposed to get them?
Justin,
post #8 of 19 Old 06-09-2013, 10:57 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1120 Post(s)
Feedback Score: 6 reviews
I've been running Matt's SRL for several years now with my stock bolts and have no issues to this point. I love the tune and I do not baby my truck.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #9 of 19 Old 06-09-2013, 11:25 AM
That sux man, sorry to hear about your new experience. I wonder if the previous owner of the truck had an edge or banks programmer, those things were partly responsible for 6.0's getting a bad rap(head bolt killers)
post #10 of 19 Old 06-09-2013, 12:03 PM
sprksonu's Avatar
gearhead SRL. i have tried them all and his SRL tune is the best all around imo..
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
