What to get next? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-08-2013, 11:27 AM Thread Starter
06 Strokin's Avatar
What to get next?
Alright guys, well I graduated highschool a week ago and I've got a little spending money for the truck. What do yall think is the best bang for the buck?....Portedintake manifold, mtw hybrid or stage one, or water/meth injection? I want to lower my egts while towing for sure and possibly gain a little power. I pull 20-24k for my job. What do yall think? Thanks guys!
-Barron
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
upgraded stc fitting
Cat ELC,
coolant filter
EGR delete
Reman tranny 126,xxx
06 Strokin is offline
post #2 of 6 Old 06-08-2013, 11:58 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
In my opinion, I'd do a ported intake manifold AND a billet wheel for your stock turbo. Pulling that kind of weight, you're not going to want to sacrifice anything on spool up and while the Stage 1 and Hybrid turbos spool just like stock, I think balancing out the airflow to all of the cylinders is going to be better for your motor than cramming more air down a tortuous flow path. From the results that I have seen from a ported intake manifold and our billet wheel for the stock turbo (separately. I can only imagine being together), I think you'll be able to get what you are after. Just my opinion of course. Hope this helps.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 6 Old 06-08-2013, 12:48 PM
In order is do a ported intake, turbo upgrade (a billet wheel for stock turbo it a stage 1) and last a water meth kit. Ported intake will distribute air more evenly, lower egts and add a little HP.
06 f350: 8" ICON 2.5 resi's, ouo ala's, pmf track bar, dual stabilizers, custom 5" exhaust, 37" BFG km2's, 4.30s, 08 tailgate w/step, 08 tail lights, coolant filter, BPB oil cooler w/p 58v ficm and radiator, ARPs, 175cc, MTW s1 billet, ported intake, egr delete, onboard air and gearhead tunes
All the above just to haul the 900hp street mustang
94slowbra is offline
post #4 of 6 Old 06-08-2013, 01:06 PM Thread Starter
06 Strokin's Avatar
Ok well sounds like I'll go with that route then. Nate, which manifold do you recommend going with? And does your billet wheel require any modifications to fit the stock turbo?
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
Cat ELC,
coolant filter
EGR delete
post #5 of 6 Old 06-08-2013, 01:31 PM
BACKYARDIGAN
Quoted: 4 Post(s)
No sir, the wheel drops right in and goes. As far as a manifold goes, there are A LOT of good options out there. If you've done any research at all you'll know that the Apex and Elite Diesel manifolds are VERY good options. I do offer three different options depending on your budget (PM me for pricing on mine). You really can't go wrong with any of those mentioned. However, from what I have heard of recently, I would STEER clear of GoGo and I don't really like the Diesel Dr manifold (unless you get the EGR delete option) because I don't think that it is that good of an improvement over the stock manifold. It does even out the flow to the cylinders I think a lot better but there aren't any improvements to the runner ports to get more flow to the motor.
In my opinion, deleting the EGR system is the ONLY way to go (unless you have emissions testing where you live) and removes a lot of turbulence in the mouth/throat area. Hope this helps.
Nate
post #6 of 6 Old 06-08-2013, 01:49 PM Thread Starter
06 Strokin's Avatar
Ok good deal! And I've done a little research on them, like you said apex and elite do seem to get good reviews! As for gogo I've read some of what has happened and I don't want that to happen to me. Lol. As for emissions testing, we don't have that where I live. Thats one good thing about small rural towns in Texas! I will get to you about pricing on yours and yes it has helped a lot, thanks again!
-Barron
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
Cat ELC,
coolant filter
EGR delete
