Converter lockup - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-07-2013, 03:22 PM Thread Starter
perez700r's Avatar
Converter lockup
Is it good to lockup the torque converter 1st , 2nd ,and 3rd gear with an sct programmer
perez700r is offline
post #2 of 12 Old 06-07-2013, 04:36 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
only in a race only tune and even then not in 1st.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 12 Old 06-08-2013, 01:30 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
PGreenSVT, what's your opinion on locking the converter in 3rd gear and up for better fuel economy? Is the tranny in any kind of danger?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 12 Old 06-08-2013, 04:26 AM
strokin6L's Avatar
Quoted: 4 Post(s)
I run my race tune as the daily driver...no issues
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #5 of 12 Old 06-08-2013, 05:31 AM
PGreenSVT's Avatar
No there isn't a problem with locking the converter from 3rd on. I would expect it to adversely affect mileage and I personally don't have my converter locked unless I'm above 65mph.
RIP Mitch
the Org crew
post #6 of 12 Old 06-09-2013, 01:08 AM
chris-rector's Avatar
Ok now I need to jump in here, I had my trans built and had a dual disc converter installed (it was free I guess a tech at the company failed to install it in another build-one of those its nice to know someone things) anyway he programmed my trans and locked the converter up in all gears should i change this with my SCT programmer?
thanks
chris-rector is offline
post #7 of 12 Old 06-09-2013, 04:27 AM
strokin6L's Avatar
Quoted: 4 Post(s)
You cant change lockup with the SCT. Your tuner has to do it in the tuning.
post #8 of 12 Old 06-09-2013, 09:18 AM
Well yeah that's what I meant I mean the program it so what should the correct lock up sequence be. I've really never understood torque converters to the full extent that I really wish I did or automatic transmissions I'm old school hot rodder from the 60's and 70's going to 4 speed on the floor
<a href="http://truckprofile.com/members/chris-rector/Ford-F350-2003/694">My Truck Profile</a>
post #9 of 12 Old 06-09-2013, 09:44 AM
strokin6L's Avatar
Quoted: 4 Post(s)
One of two ways...either early lockup or late. Early lockup will lock converter in 3rd 5th and OD. Where as late will only lock it up after OD.
post #10 of 12 Old 06-09-2013, 12:37 PM
SpeedyDBall's Avatar
What do you guys perfer? Im about to order a TW extreem tune, not sure about early lock up though. I will DD this tune if that changes things any.
'05 6.0 FX4 Lariat DRW:ARP, OEM HG's, Fully Updated, 03 turbo, Warren 155/stock, Pillar Guages(Boost, TFT, EGT, Oil Pressure), Fuel Pressure, Scan Guage 2, 6.4 banjos, Blue spring, MBRP straight pipe, SCT with Nate's tunes, Zoodad, DIY CCV Mod, coolant filter, T6, Final Charge ELC, Strategy VXCF4, Eco tuned FICM
Ficm Repair.com is the $%^&!!!!!!! Great service, and Ed is great to work with. Highly recommended!!!!!!
SpeedyDBall is offline
