Time for upgrades - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-07-2013, 08:35 AM Thread Starter
btr2bstrokin's Avatar
Time for upgrades
I am starting my next project replacing the Oil cooler, EGR Cooler , and FICM next weekend when I get my parts. I am also going to add the Sinister Coolant Filter as well.
What coolant should I get and how much? Also what other extra parts and/or gaskets will I need when I tackle this project. Any help is appreciated. Thanks for looking.
2007 F-250 CC SB, SCT X4, Insight CTS, Silverline Exhaust into 5" tip, AFE Stage 2 Intake, BPD Egr Cooler, BPD FICM, Sinister Coolant Filter, ARP Head Studs, Fog Light Mod, Zoodad Mod, High Idle Mod
btr2bstrokin is offline
post #2 of 11 Old 06-07-2013, 02:30 PM
turbotibbo's Avatar
I would also look in to the blue spring upgrade , while you are doing this to your truck . do a few google searches and you will find all the info you need and mabey a few videos on you tube . its a straight forward job and I had fun when I did mine . here is a link a member gave me when I asked for advise Oil cooler and EGR cooler service PDF files and notes
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #3 of 11 Old 06-07-2013, 06:00 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Are you flushing it as well? Be fooliish not to. 30 gallons of distilled water 4 gallons of ELC concentrate. Napa sells Zerex under part # ZXED1. If it isn't on the shelf they can have it next day sometimes same day.
RIP Mitch
the Org crew
PGreenSVT is offline
post #4 of 11 Old 06-07-2013, 06:04 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
I use Zerex! The coolant system takes about 7 gallons of coolant.
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #5 of 11 Old 06-07-2013, 11:50 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Tom, it is gallons total capacity. 4 gallons of concentrate mixed with the 2-3 gallons of water still retained in the system after draining.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #6 of 11 Old 07-27-2013, 05:38 PM Thread Starter
I finally got around to doing some work to the truck about a month ago. I did the BPD egr cooler, oem oil cooler, Cat Rated coolant and BPD FICM, and Sinister filter. Today driving home from a funeral I noticed when leaving stop signs and stop lights I was getting puffs of white smoke. I got home and looked at the coolant. I have lost some at some point. Could my problem be my coolant filter not being changed within the inital 500 miles or another problem? I haven't noticed any power loss but then again I haven't been running the hell out of. Any feedback will be great.
post #7 of 11 Old 07-27-2013, 05:58 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 56 Post(s)
Feedback Score: 7 reviews
Sounds like Egr is leaking coolant into exhaust. Park the truck nose pointed down and pull the Egr valve and check for coolant.
God bless America, the Constitution and the Second Amendment.
powerstrokeshellback is offline
post #8 of 11 Old 07-27-2013, 06:19 PM Thread Starter
So it could just be an egr valve? Is there an easy fic with that or have to buy a new one if thats what it is?
post #9 of 11 Old 07-27-2013, 06:23 PM
Quoted: 56 Post(s)
Not necessarily. If there is coolant your egr cooler is bad.
post #10 of 11 Old 07-27-2013, 06:25 PM Thread Starter
So I got a faulty cooler from bulletproof? If I dont have coolant, what else could it be?
