what tune to tow with, studded truck - Ford Powerstroke Diesel Forum
post #1 of 42 Old 06-06-2013, 09:36 PM Thread Starter
ssdeuce's Avatar
I am using vivians tow tune, but would like to know what everyone is using on studded trucks at or under 8000lbs
I MAY BE CRAZY BUT I AIN'T DUMB
04 F250 6.0 FX4 CC SB
S&B intake
CFM+ INTAKE ELBOW
4" TURBO BACK STRIAGHT PIPE NO CAT
SCT W/ VIVS TUNES
ZOODAD MOD
SUPERCHIPS DUAL LAZER GAUGE (EGT&BOOST)
ford blue spring
banjo bolts
and heck its my slowest vehicle
gotta work on that
ssdeuce is offline
post #2 of 42 Old 06-06-2013, 09:55 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I use Matt's 8k tune... I think he says 10k is okay with a studded truck but I might me wrong as I just recently did my bulletproof endeavor and I bought the tow tunes 2 1/2 years ago.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 42 Old 06-06-2013, 09:58 PM
Quoted: 8 Post(s)
I once crossed the scales (not at a weight station but a rock quarry) at 24,xxx and I was using his 8k tune. Only had to slow down once and that was because I was traveling up an 6% for about 4 miles and the EGTs where getting high.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #4 of 42 Old 06-07-2013, 06:50 AM Thread Starter
ssdeuce's Avatar
I might have to try matts tunes, I hear they are clean, my looney runs good but alot of smoke. Im also sending out the ficm for repair and the atlas 40.
S&B intake
CFM+ INTAKE ELBOW
SCT W/ VIVS TUNES
ZOODAD MOD
ford blue spring
banjo bolts
gotta work on that
ssdeuce is offline
post #5 of 42 Old 06-07-2013, 06:54 AM
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
I just put MAtts unlimited tow on this morning.I have not towed with it yet,but next week we go camping.I also have Vivian's non aggressive tune,and honestly like it the best so far.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #6 of 42 Old 06-07-2013, 07:28 AM Thread Starter
ssdeuce's Avatar
I have the aggressive cause I dont ever tow over 8k. Its been great and maybe the ficm is way I feel like shes lugging a little
S&B intake
CFM+ INTAKE ELBOW
SCT W/ VIVS TUNES
ZOODAD MOD
ford blue spring
banjo bolts
gotta work on that
ssdeuce is offline
post #7 of 42 Old 06-07-2013, 08:25 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 108 Post(s)
Feedback Score: 3 reviews
I run the Looney Wild with Atlas 40 while towing my boat. It gets the EGTs up but not out of control.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #8 of 42 Old 06-07-2013, 09:11 AM Thread Starter
ssdeuce's Avatar
I towed on my looney last weekend but she started running hot on the way home. Made me a little nervouse
S&B intake
CFM+ INTAKE ELBOW
SCT W/ VIVS TUNES
ZOODAD MOD
ford blue spring
banjo bolts
gotta work on that
ssdeuce is offline
post #9 of 42 Old 06-07-2013, 09:16 AM
Quoted: 8 Post(s)
Matt's tunes (especially his SRL) are probably the cleanest tunes out there. Absolutely my favorite part about his tune.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #10 of 42 Old 06-08-2013, 08:46 PM
bondajb's Avatar
What is hot??? I will hold 1350 all day if needed.! I run Vivian's tow and agg tow. Great files! Her tow with jake I am pulling 17k & with her agg tow pull 8k.
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
