FAILED PUMP TORN DOWN PIC HEAVY! - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-06-2013, 04:29 PM Thread Starter
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
OK got a 04 in today with a no start. had low icp code so first thing I did was trusty dusty air test. this was late 04 so icp is on pass side valve cover. Applied shop air and put ipr at 94% and heard no air leaks at all. So I dropped ipr to 0% and heard it exhaust so I ramped up ipr to 94% in stages and could not get it to close. Pulled ipr and there was no screen GONE! Looked inside ipr hole with bore scope and empty no screen? Installed new ipr and redid air test this time it followed commands! Tried to start and nothing ipr at 85% and no fire in the holes!! Redid air test and nothing no air heard so I remove oil filter cap and gurgle gurgle HUMM there ya go!! So this time I really want to know whats going on inside the pump!!! What is going bad! This is what I found. Pics will be in order of how I took it apart! notice the clip impressions in back of pump plate!
AND THIS IS HOW THE AIR PASSES FROM HIGH PRESSURE OIL SIDE TO LOW PRESSURE
THIS IS A GOOD ONE
THIS IS THE LAY OUT NOTICE OFFSET
Call me anal but I like to know what fails and understand why it fails rather than just replace things because there bad! I hope you guys and gals like this!
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #2 of 14 Old 06-06-2013, 04:40 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Nice Dale. Can you rebuild that pump?
Oh yeah you said input welcome in that one pic. Well my input is wear surgical gloves or clean under your nails. LMAO. I know I know it is impossible to keep your Delta Bravo's clean when working on vehicles. Just giving you chit.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 14 Old 06-06-2013, 04:41 PM Thread Starter
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
lmfao got me again!!!
A/C ASW A/W WINGS
post #4 of 14 Old 06-06-2013, 06:43 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1610 Post(s)
I like it I wanted to do this with the last one I had as well but boss wanted to core charge back so no go. I have always wondered what they looked like inside. Also are there rebuild kits avalible? I would think someone has to have somthing for these with the companys that rebuild and modify the pumps. I would like to get my hands on a rebuild kit and try it.
toren302 is offline
post #5 of 14 Old 06-06-2013, 07:08 PM
04cr450's Avatar
Great work dale. Very detailed buddy thumbs up.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #6 of 14 Old 06-06-2013, 07:19 PM Thread Starter
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
I would imagine there are but the peace that is bad is part of the whole housing so it is wasted! This is a core and will go back in peace's lol.
A/C ASW A/W WINGS
post #7 of 14 Old 06-06-2013, 07:20 PM Thread Starter
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Thanks Greg curiosity kills me not the cat!
A/C ASW A/W WINGS
post #8 of 14 Old 06-06-2013, 07:30 PM
Mine looked the same on the inside just not that much scoring around the plungers. It would only build 1500 psi before the ipr would climb. Hell the guy at ford asked me if I took it apart I said yes they know me way to well not to tear stuff apart.
03 f-250
blue spring
4inch turbo back exhaust
egr delete
MTW HYBRID
SCT livewire
scan gauge w egt
zoodad mod
fuel press gauge
225,000 miles
155/stock holder diesel
tatertot is offline
post #9 of 14 Old 06-06-2013, 07:42 PM
I have an 04 E350 late model and the HPOP went in Dec. The outer cylinder of the compression head(my words because I have no idea what that part is called) seem to rotate during a failure. I wondered why there is no key way to prevent that item from turning. There must be a lot of torque when it is at pressure. Six months before the failure I had started running my SCT a little harder. Also I had lost pressure in OCT because of the housing port ball had been pushed out. The mod I did to fix the ball from coming out was to tap the hole and put a brass plug in it. All that being said I though I caused the over pressure that caused the "compression head) to rotate. After seeing the exact same failure in your pics I am now sure it is something different.
My E350 is awesome and a lot like a helicopter. For every one hour on the road equals two hours in the shop...
methayn is offline
post #10 of 14 Old 06-06-2013, 07:44 PM
One other note that I have a question on, what happens to the alloy that is ripped off of that pump. I think it is what causes the damage you label as from cavitation. Then all that metal is sent tot he injectors.
methayn is offline
