03 pstroke mods 600HP maybe:) - Ford Powerstroke Diesel Forum
post #1 of 115 Old 06-05-2013, 10:53 PM Thread Starter
Hi my name is Collin, i just got out of the Marines and back stateside for good...finally lol. I bought a 03 F-350 6.0 bout three years back, was wanting some opinions as well as insight on what im bout to do. The part list below is everything that is goin on next week. What kinda power should be pushing is my guess with proper tuning around 600HP. Tunes will be through GEARHEAD on a SCT LIVEWIRE. All opinions or ideas on parts or tunes or anything concerning trucks performance are appriciated thank you.
05/22/2013 ARP HEAD STUDS 480.00T
05/22/2013 cylinder Head Gaskets
05/22/2013 ROCKER BOX GASKET 75.82T
05/22/2013 glow plug o ring 7.12T
05/22/2013 Intake gasket set 68.91T
05/22/2013 Oil cooler 6.0 321.05T
05/22/2013 HIGH PRESSURE OIL PUMP GASKET 32.05T
05/22/2013 Thermostat 6.0 38.60T
05/22/2013 ENGINE BELT 68.25T
05/22/2013 Coolant ELC 46.38T
05/22/2013 Oil filter and oil replacement 75.00T
05/22/2013 TO INSTALL ARP HEAD STUDS,
OIL COOLER, EGR COOLER 25 HOURS
UPGRADE, CLEAN INTAKE, CHANGE OIL AND FILTER, FLUSH
COOLING SYSTEM, THEMOSTAT AND ENGIEN BELT. 1,750.00
05/22/2013 68mm PowerMax turbo 2,250.00T
05/22/2013 Regulated return Fuel System 467.09T
05/22/2013 SRL+, 8k tow and unlimited tow 100.00T
05/22/2013 FASS FUEL SYSTEM 780.00T
05/22/2013 205cc injector set 1,799.99T
05/22/2013 TO INSTALL REGULATED RETURN AND FUEL SYSTEM, DROP
FUEL TANK AND INSTALL DRAW STRAW IN FUEL TANK 5 HOURS 350.00
Estimate
collinsmith is offline
post #2 of 115 Old 06-06-2013, 01:23 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
What are your plans for your trans? It probably won't hold for long. There are sticky's that list all parts someone should consider when going that far into the motor.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 115 Old 06-06-2013, 03:25 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
All this will not get you 600rwhp. Why would you want that anyways. Go buy a mustang. You are looking at some pretty sh1ty fuel mileage too.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #4 of 115 Old 06-06-2013, 04:55 AM
twildman's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
You should be a right around the 6 mark, maybe a tad over.
Custom tuning for your 1994-2010 Powerstroke Diesel
Full line of performance products for all brands of diesels
05 King Ranch with some stuff on it.
twildman is offline
post #5 of 115 Old 06-06-2013, 04:57 AM
twildman's Avatar
Quoted: 2 Post(s)
Really? Why would you post that? Why in the world do you care if he wants a 600 hp or a 1000hp truck?
And tell my why fuel mileage is a concern with these trucks in the first place, you want fuel mileage, go buy a VW TDI.
twildman is offline
post #6 of 115 Old 06-06-2013, 06:12 AM
Turbos = Witchcraft
TooMuch03's Avatar
FWIW, I have gone from 185/70s to 155/100s to 255/150s for injectors, and my fuel mileage has not changed at all. The combination of 205s and the 68mm powermax have proven 600 hp time and time again. At that power level, your transmission is going to hate life.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #7 of 115 Old 06-06-2013, 07:15 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
Really, why would YOU post that? Why do you care about my opinion? Ether you agree our disagree with it. I happen to get great mpg and hover at 520 rwhp. I asked him why he wanted 600 hp now be a big boy and let him answer cupcake.
WarChild is offline
post #8 of 115 Old 06-06-2013, 07:17 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
I was not aware that that was a time and time again proven fact that's my bad. He might want to add a tranny to that list then. I have seen guys trash their trans at 500 so at 600 I'm sure it will be screaming at him. I did have a change in my mpg when I changed injectors but it got better.
WarChild is offline
post #9 of 115 Old 06-06-2013, 07:24 AM
Boy, war child is just full of positivity this morning.... Tony can you write a tune called Cupcake now? That would be badass
harrisford is offline
post #10 of 115 Old 06-06-2013, 07:26 AM
Marine Raiders>Seals
najaf4life's Avatar
You will need to beef up your transmission.
RYAN
03 Excursion 6.0L
BPD,WPE & other odds and ends
najaf4life is offline
