sct and egt problems - Ford Powerstroke Diesel Forum
Old 03-16-2008, 02:18 PM
i just bought the sct livewire from innovative diesel with tunes from eric, after subscibeing to this chat room everyone convinced me it was the way to go. so i yanked the edge. but know i have huge egt problems when running the extreme steet tune it will hit 1600 i have 4" exhaust, banks intake and intercooler
Old 03-16-2008, 02:22 PM
im fat and ugly
you need to call eric and have him tweak the tune for you he will get you right.
Old 03-16-2008, 02:23 PM
Rob Rob is offline
1600 is pretty hot bud! see if Eric can tune it down a bit. oh yeah, Welcome to the site!
Old 03-16-2008, 02:25 PM
DKR DKR is offline
<--Pro Cooler Racer
Whers is your EGT probe placed?
Or, contact Eric to make sure all his settings transferred properly.
Old 03-16-2008, 02:35 PM
it is on the drivers side manifold in the very back
Old 03-16-2008, 02:38 PM
when i had the edge it would read about 200 degrees cooler than my gauge
Old 03-16-2008, 03:37 PM
1600 is pretty warm, you'd have a hard time hitting those EGT's on stock injectors. A set of 190cc injectors and you may hit those temps on a stock turbo. My guess is the gauge is off. Either way, I can definitely pull some fuel. Email me and I'll tone it down a bit. Thanks!
Old 03-16-2008, 03:59 PM
It sounds like you may have your probe directly in one of the exhaust ports. I would check with another gauge before you condemn the tune. With Eric's Xtreme Street I have a hard time seeing much over 1200 degrees.
Old 03-16-2008, 04:02 PM
i would rather not tune it down i love the power. for some reason the street ran hotter than the race. would you trust the edge gauge or a cheaper analog gauge. if it will work i'll hook the edge back up and run it on the stock setting
Old 03-16-2008, 05:53 PM
That can't be correct or you'd be losing power. At over a constant 1550 you'd be melting the corners off or your factory
turbo fins!!!!!!
