75 percent nozzles or a Ported Intake - Ford Powerstroke Diesel Forum
post #1 of 53 Old 06-04-2013, 10:22 AM Thread Starter
Stumppy's Avatar
Im getting ready to order the parts for my build. I was going to go with 175 stock nozzles but after doing a little reading Im thinking of going with 175/75 injectors. I also want a ported intake but cant afford to do both right now. What do you think would be the better setup? The ported intake manifold or the 75 nozzles for my injectors?
2004 CC SB 6.0
4 Inch Turbo back Exhaust
S&B Intake
Sct with Vivians looney wild tune.
Egr Delete
Arp Head studs and oem gaskets.
Stumppy is offline
post #2 of 53 Old 06-04-2013, 10:28 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I would do the ported intake manifold first.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 53 Old 06-04-2013, 10:33 AM
PGreenSVT's Avatar
Feedback Score: 3 reviews
And I wouldn't get those 175's with anything bigger than 30 nozzles. It's easy enough to port your own intake, especially if you can weld aluminum yourself. If not all you have is the cost to weld it back together.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #4 of 53 Old 06-04-2013, 10:35 AM
william_ace's Avatar
Quoted: 2 Post(s)
I would do 175/stock injectors with a ported intake. 175/75s are too large and will need to be defueled so they do not smoke like a train.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #5 of 53 Old 06-04-2013, 10:42 AM Thread Starter
Stumppy's Avatar
I will be getting a mtw stage 1 with it also so the smoke shouldn't be bad. I can weld pretty good so I may just try making my own manifold. Never really thought about doing my own.
2004 CC SB 6.0
S&B Intake
Egr Delete
Stumppy is offline
post #6 of 53 Old 06-04-2013, 10:43 AM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Yeah if youre truck will be apart, Id do the manifold ( as its beneficial on both stock inj. and aftermarkets. ) And the injectors are a bit easier to change out later in the game.
MrOneEyedBoh is offline
post #7 of 53 Old 06-04-2013, 12:17 PM
jetjock15's Avatar
Quoted: 110 Post(s)
After tearing into my engine on four different occasions after I save up for manifold and all ford updates like STC and standpipes, then studs, then BPD oil cooler kit, then last time injectors & turbo - that was redicukous. If I had to start over I'd wait to afford it all or put some on a credit card!! Doing the work twice I coulda done once was bad idea! Oh well what's hard to endure is fond to remember...
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #8 of 53 Old 06-04-2013, 12:19 PM Thread Starter
Stumppy's Avatar
Lol I hear that. I'm not even sure I really want the nozzles. I'm not looking to make a drag truck just a bit more power.
2004 CC SB 6.0
S&B Intake
Egr Delete
Stumppy is offline
post #9 of 53 Old 06-04-2013, 12:35 PM
peixinho's Avatar
Quoted: 179 Post(s)
I just did mtw stage 1 with 175cc/stock nozzles and the mtw stage 1 will not clear them up all the way... it gets close. I see no reason to go with nozzles. I would do the manifold or pay the extra for the hybrid turbo.
175cc/stock nozzles = $700
175cc/75% nozzles = $1400
That will not get you much more hp and will cause major egt's
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #10 of 53 Old 06-04-2013, 12:46 PM
BACKYARDIGAN
Quoted: 4 Post(s)
175cc injectors are still too big for the hybrid turbo too. I can assure you that the difference in airflow between the two is SO nominal that the extra money that would be spent getting the hybrid would be WAY better spent on being put towards a fully ported intake manifold. The Stage 1 (especially since it comes standard with the billet wheel) is a dandy little turbo and allows me to drive around fine with my 190/100s and the right tuning. As long as I don't get into it, EGTs stay under 1000F even driving around on the switch backs of WV.
Nate
