New 190/50s MBM - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-04-2013, 10:17 AM Thread Starter
twoicebergs's Avatar
Quoted: 46 Post(s)
New 190/50s MBM
Here are the latest injectors I built and installed. Start-up was pretty smooth with about two 15-20 second cranks. They run very nicely, but I still can't believe it blew off the hot pipe boot at the turbo! I had it cranked down as usual. Go figure.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #2 of 13 Old 06-04-2013, 10:21 AM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Do you have a company or just a joe schmo that likes making/building his own stuff? Just wondering, thats all. Do you flow rate your injectors?
MrOneEyedBoh is offline
post #3 of 13 Old 06-04-2013, 10:35 AM Thread Starter
Quoted: 46 Post(s)
The nozzles are flowed. The cut is exact enough to give accurate displacement flow and there is no shop within 1500 miles that can flow test HEUI injectors for me. I just like to tinker, but I have done a few sets for others. Being in Canada, living out of town and frequently working out of the country, is a bit of a PITA to make it worth doing commercially.
Frank
Working for Toys
post #4 of 13 Old 06-04-2013, 10:41 AM
Quoted: 13 Post(s)
Yeah, well congrats man and sounds damn good.
post #5 of 13 Old 06-04-2013, 12:50 PM
turbotibbo's Avatar
nice , id love to be able to do that kinda upgrade to my own injectors . id love to see a video of the truck driving as well
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #6 of 13 Old 06-04-2013, 01:21 PM
Fox Hunt's Avatar
Quoted: 26 Post(s)
Sounds good. What turbo you running with them?
Sent from AutoGuide.com App
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #7 of 13 Old 06-04-2013, 01:30 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Good job Frank.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #8 of 13 Old 06-04-2013, 02:42 PM Thread Starter
Quoted: 46 Post(s)
The one in my sig, an LLY conversion (63.5/88 on the powerstroke hot section) that I built pretty muck like Adrian did when he did his first few stage 1s. It is an awesome turbo compared to stock, but just not enough to make me happy about the smoke on full fuel. However, if you drive it nice it doesn't smoke at all. With the new injectors it still is haze to smoke up top, but much better in the mid section. I have never seen a really bad temp yet with any tune I have run. I just bought another turbo for a different project that I still have to get moving on. But it might get hijacked for an intake mod first, we'll see.
Frank
Working for Toys
post #9 of 13 Old 06-04-2013, 04:56 PM Thread Starter
Quoted: 46 Post(s)
Here are some pics. I am still not completely happy about the ICP at 3,000psi. The 82% IPR may be giving some HPO away? It may be due to the PW?
The 1640rpm is 60 mph. Others are in acceleration Max temp was in xxx speed in x gear.
Frank
Working for Toys
post #10 of 13 Old 06-04-2013, 05:07 PM Thread Starter
Quoted: 46 Post(s)
This is the smoke trail. It is actually pretty clean compared to the 75% nozzles.
________________
45-65 in 5th gear.
____________________
60mph slow roll in to max boost.
Frank
Working for Toys
