i went to the drag strip today, thinking i was going to post a fast time but nothing my first run was in 2wd chip in performance and i only got a 16.01 at 81miles i was mad so i went back lowered the bed,close the mirrors still in performance 2wd i built boost to about 10psi and i got a 16.09 reaction time in the first one got a .o80 and the second .200 so i let it cool down before i run some more went there turn the chip to extreme in 2wd i spin really bad i got a 19.6 went back but it in 4wd and got the best time of the night 15.4 at 84miles went 3 more times but i can only get 16s. sorry for the long post my question is whats the next modd i can do to make run faster????? i got a 2004 crew cab 4x4 with an aem intake,straight pipe no cat no muffler in 3.5 inch and for programmer i got the bully dog triple with the outlook set at extreme, im running 35 inch tall tires and they were at 38 pounds of air
I think you should do the bully dog delete mod.
SCT MAN!!!!
i know i got this one for really cheap from a member here in the org,i wish i can afford a limewire with some custom tunes...
Im just messing with you man. If you got it cheap then more power to ya..I paid 400 to my door for my xcal 2. Unlimited tunes from DJ. I want to hit the track soon. I hope Im not disappointed.
Lol that was pretty good. The cheapest way to get more power would be with the SCT. A good race tune should get you down to the mid to low 14's.
Sorry man gotta give ya a hard time! j/k But on a serious note a SCT would give safer and more reliable power, IMO than the bully dog. That is just my thoughts.
Put it in 4x4 and do a boosted launch, get it up to like 15 boost and let er rip. you should atleast make it in the high 14's. Other than that, get a custom tuned SCT.
I have a qick question, does anyone have any knowledge or experience with the MBRP power pipe? Also my pyro reads around 800 when I'm cruising at about 70 is that a normal temp? Thanks.
That seems pretty high for just crusing. Mine is usually at about 550-600 at 70. That is running innovatives xtreme street tune.
You're bigger tires will give you just a bit more heat. Mine runs around 600 or a little more at 70 mph on flat ground. I don't think you're too far off considering the lift and tires.
